Help with bandsaw
Forum topic by jim1mckenna posted 01-23-2010 05:07 AM 1359 views 0 times favorited 11 replies Add to Favorites Watch
View jim1mckenna's profile
jim1mckenna
51 posts in 3059 days
01-23-2010 05:07 AM
Topic tags/keywords: question help
I just got a 18” band saw the thing is I found out it was a metal cutting band saw does anyone know if there is a differants in a metal and a wood cutting band saw and if so what are they and can this thing be converted to cut wood.
I posted this before and didnt get much response so if nyony knows nything about this caan you help
11 replies so far
View interpim's profile
interpim
1170 posts in 3426 days
#1 posted 01-23-2010 05:19 AM
is it vertical or horizontal?
-- San Diego, CA
View hairy's profile
hairy
2658 posts in 3500 days
#2 posted 01-23-2010 08:49 AM
I will assume you have an upright band saw. The main difference is blade speed. Metal cutting will be about 25% of the speed for cutting wood,depending on the type of metal. The blades are different. Think of a hacksaw and a hand saw.
-- My reality check bounced...
View hvroberts's profile
hvroberts
40 posts in 3250 days
#3 posted 01-23-2010 06:59 PM
It’s all in the blades and the speed. You have to buy a metal cutting blade and slow down the speed. Other than that, you cut wood.
-- Hvroberts, Up North In Maine
View jockmike2's profile
10635 posts in 4214 days
#4 posted 01-23-2010 07:19 PM
You need to answer your forum posts if you want answers. Just trying to be helpful. hvroberts meant you have to buy a wood cutting blade.
117063 posts in 3545 days
#5 posted 01-23-2010 07:21 PM
What hvroberts said
View MedicKen's profile
MedicKen
1612 posts in 3430 days
#6 posted 01-23-2010 07:27 PM
http://lumberjocks.com/topics/13707#reply-140785
View heatpumpproducts's profile
heatpumpproducts
6 posts in 3013 days
#7 posted 01-23-2010 07:43 PM
what brand name saw do you have and what type vertical or horizontal , the guides will be different and the motor speed , and the blades will not be as suitable for soft wood , but mite work with some hard woods . it depends on the degree of skiils you have . if its a horizontal , you could in fact turn it into a resaw , the wider the throught the better , but you will also be looking to use deeper blades and a conveyer type belt to carry the wood through and some sort of a hold down springed wheel or roller to keep the wood flat to the conveyer as it passes through the blade 3tpi carbides would work great , and more than 2 hp . if its a vertical set up then it is posible that the table will not tilt but you can make one that has a fence and tilts using counter top and plywood as it base and house hold door hinges . the fence need to be adjustable but able to be fixed when cuting . a measuring guide inbeded in the top will save you lots of time with set up .
free hand work is best done with thiner front to back blades of 3/16 to 1/2”with 4tpi or more and ripping thicker blades front to back 5/8 to 3/4”with 4tpi or less. speed adjustment is a very nice option in band saw use , but it is personal preference in the end .
As long as you feel comforetable , the bandsaw is one of my favorite tools . never place your fingers in the path of the blade , use a push block .
-- Kier Mizuik,Miramichi ,New Brunswick,Canada ://www.heatpumpproducts.com
#8 posted 01-23-2010 09:06 PM
Well I guess I should clarify Cutting wood requires wood blades(just like Jockmike said) on the band saw the metal blades teeth are to close together and not aggressive enough. The speed of a metal cutting band saw may be different so it may mean you have to adjust the feed rate of the material. I agree with using a push stick for sure.
jim1mckenna
#9 posted 01-24-2010 05:15 AM
sorry I am out of town for work and haavent had the time .it is a upright Dayton 6Y942B 18” bandsaw. it is for cutting metal only it speed is 50 80 and 200 FPM what I wont to do is confert it if possable to cut wood I know how to use a band saw I know the differants in blades and how to work a saw the question I amm trying to ask is does anyone know the steps if possable to confert to cut wood. I did find out that the speed is way to slow and it is not going to cut wood good at all. it has some kind of gear box the I think makes it go slow for wood so maybe I have to take it off and put some kind of pully on ot for a faster speed.
View KnotWright's profile
KnotWright
258 posts in 3456 days
#10 posted 01-24-2010 05:46 AM
Just curious, is this your bandsaw?
http://yabe.algebra.com/~ichudov/misc/ebay/Dayton-6Y942D-Metal-Wood-Bandsaw/ebayhist.html
Was trying to do a little online research for you, to see if you could just change out the pulley to increase your speed.
-- James
jim1mckenna
#11 posted 01-24-2010 09:57 PM
No That is close to mine the differants is mine has a B at the end not a D and it is only fr cutting metal
