Incra Wonder Fence on a Bench Dog ProMaxRT Cast Iron Table
Forum topic by Mordi posted 01-07-2016 12:43 AM 687 views 0 times favorited 1 reply Add to Favorites Watch
View Mordi's profile
Mordi
36 posts in 1311 days
01-07-2016 12:43 AM
Just wondering if anyone has successfully mounted an Incra Router Fence on the Bench Dog ProMaxRT Cast Iron Table Top?
From what I have read, the brackets that come with the fence will only accomodate router table tops that are up to 1 3/8” thick and the Bench Dog Cast Iron Table is 1 1/2” thick – so some sort of modification is necessary to secure the fence to the table. (FYI – this is the standalone cast iron top – not the extension wing to the TS).
Thanks,
Mordi
1 reply so far
View greenacres2's profile
greenacres2
320 posts in 2168 days
#1 posted 01-07-2016 01:28 AM
Shouldn’t be a problem. If the top was solid, it would just take longer bolts than what are included in the package. I’m guessing that the Bench Dog top is not 1 1/2” thick all over—but likely webbed. So, careful drilling would get you to where the thickness is under 1/2”. Another possibility would be to drill through where you choose, and run about 3” mounting bolts through the mounting bracket, top and a 3/4” plywood backer under the webbing.
Incra writes great manuals, but for the most part they are geared to what’s included in the kit for fasteners. This is one that should be relatively easy to overcome. I’ll measure the centers of the bolt holes on my mount so you can look at the top from the underside for drilling locations.
earl
