HF router table plate? any good?
Forum topic by MichaelMacD posted 01-23-2010 01:32 AM 2805 views 0 times favorited 5 replies Add to Favorites Watch
View MichaelMacD's profile
20 posts in 2988 days
01-23-2010 01:32 AM
Anyone have experience with the HF plate? is $19… much less than rockler and woodcraft products. have to drill your own holes though…
5 replies so far
View Jeison's profile
968 posts in 3042 days
#1 posted 01-24-2010 06:59 AM
I don’t know about the HF one (my local HF doesn’t carry them) but the few reviews I’ve seen made it sound like sagging was an issue. May want to check our Router Table Depot, they have blank 3/8 acrylic inserts on sale for $17, and their own deluxe insert is $32.
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View knotscott's profile
7938 posts in 3310 days
#2 posted 01-24-2010 12:02 PM
The HF plate is phenolic AFAIK, and looks identical to a few others that are sold from different suppliers. I have two phenolic plates from Hartville Tool (Hart Design) that I’ve been very happy with.
Hart Design:
View rwyoung's profile
409 posts in 3406 days
#3 posted 01-24-2010 07:13 PM
It is a clone of the Rouseu plate. Works pretty well. For $19 (and under with the 20% coupons) you can’t go wrong.
That said, the one annoyance I’ve had with mine is there seems to be a little bit of difference in either ring thickness or the depth of reveal in the plate. If I snap the ring in one way I can feel a little ridge that can catch the edge of a work piece. Snap it out, rotate 60 degrees and snap back, no ridge.
I keep forgetting to mark the ring and plate for orientation, hence the annoyance.
I have the Craftsman version of the PC 890 hanging from it and so far no droop. However I do try to remove the router body from the base if I’m not going to be using it for a few days.
Drilling the holes is no big deal. On the bottom of the plate are a series of concentric rings. Remove the plastic plate from your router base (need to anyway) and use that as a template for marking the holes. The rings stamped on the underside of the HF plate help you center the template. Over size the holes just a smidge so that you can use a centering cone to fine tune the placement of the router base.
-- Don't sweat the petty things and don't pet the sweaty things.
View Ger21's profile
1074 posts in 3065 days
#4 posted 01-24-2010 07:25 PM
Never seen the HF plate, but I have used a Rousseau, and am not a fan. A much heavier duty plate is the Woodhaven.
-- Gerry,
#5 posted 01-26-2010 07:09 PM
rwyoung—good to hear that there is an easy way to center the subbase… I just ordered it this weekend, and I have been wondering how hard it would be to get the holes marked with the subbase dead-on center. I will experience with orienting the inserts a few ways and see if it produces any ridges… thanks
I looked at the $17 blank right now… I think the $19 with the pin and the removable inserts is a better deal… we will see.
