Paint/stain before glue?
« back to Joinery forum
Forum topic by CudaDude posted 01-06-2016 06:03 PM 502 views 0 times favorited 2 replies Add to Favorites Watch
View CudaDude's profile
CudaDude
179 posts in 2213 days
01-06-2016 06:03 PM
Rainy day here, work is really sloooow and my mind is just wandering. Got to thinking about cabinet cases with fixed shelving inside. I would want to spray all the panels before assembly, but once sprayed, the areas where the glue joints will be would be sealed by paint. Do most just try to avoid spraying the areas/joints that will have glue and not worry with some overspray? Seems like taping off those areas would have so so results. What method would you use? Thanks
-- Gary
2 replies so far
View CB_Cohick's profile
CB_Cohick
484 posts in 1156 days
#1 posted 01-06-2016 06:12 PM
I have not run into issues with glue not working with painted or stained surfaces. Going the other direction is the problem, especially in the case of stains.
-- Chris - Would work, but I'm too busy reading about woodwork.
View ChrisK's profile
ChrisK
1912 posts in 2986 days
#2 posted 01-06-2016 07:48 PM
When I paint, I glue first. When I stain, I stain first.
-- Chris K
