Animal safe clear coat question
Forum topic by Kristoffer posted 01-06-2016 03:36 AM 1218 views 0 times favorited 5 replies Add to Favorites Watch
View Kristoffer's profile
Kristoffer
675 posts in 3214 days
01-06-2016 03:36 AM
Topic tags/keywords: animal safe finish cedar bird feeder
Does anyone know of an animal safe clear coat finish? I’ve been making a lot of bird feeders out of cedar. Obviously, the cedar holds up pretty well, but I’d like to stain and paint some of the parts. That being said, it’s going to need to be protected. What can I use, that isn’t $30 an ounce?
Kristoffer
-- Cheers and God Bless
5 replies so far
4986 posts in 2491 days
#1 posted 01-06-2016 12:29 PM
All finishes are non toxic any more, that said if they are cedar they really don’t need protection. It’s well suited for outdoor use as is, although it will whether to a plain gray color. Even so, if you want to finish it the finish will need a few properties: the best choice would be the marine spar varnishes….but that’s the $30/oz stuff (not quite, but I get your point). What I suggest is untinted paint. I’ve used it on cedar feeders and it works quite well and lasts a long time. More info here, buy if you live in an area without oil based paints (the article suggests them) you can get the water borne formulas instead. I know the SW A-100 exterior will dry clear as will the Olympic Premium Exterior Acrylic and they have the UV protection. Be aware, no clear outdoor finish is a forever thing, they will need repair eventually…tbut these last a very long time and are affordable. Lastly, another good choice might be the General Finishes High Performance…same properties but maybe a tad more expensive.
Edit: I suppose that small pieces of any film finish swallowed by a bird could damage it’s intestines or such, but that’s the only possibly I can think up.
View OSU55's profile
OSU55
1672 posts in 1988 days
#2 posted 01-06-2016 12:51 PM
Thanks Fred, that’s about the best test for outdoor finishing I’ve read, and provides great information. For exterior use pigment is best, but if someone must have “clear” it seems the clear base paint is the best choice. I was unaware the pigment was reduced to nothing in the last base number.
#3 posted 01-06-2016 01:04 PM
OSU55, I’ve used several gallons of the oil based exterior paint unitinted and it really is a good finish…looks very much like an oil based varnish once applied. I’m not sure why this isn’t more popular, it works well and is cheaper than most of the alternatives.
OSU55
#4 posted 01-06-2016 09:41 PM
I suspect its simply awareness
View stefang's profile
stefang
15881 posts in 3332 days
#5 posted 01-31-2016 04:29 PM
An inexpensive and easy to apply finish would be something more elastic like a Danish finish for example which contain about 1/3 oil, 1/3 poly and 1/3 white spirit.
