Farm table glue up
« back to Joinery forum
Forum topic by devillier1 posted 01-06-2016 01:52 AM 810 views 0 times favorited 8 replies Add to Favorites Watch
View devillier1's profile
11 posts in 967 days
01-06-2016 01:52 AM
I need some advice from my fellow workers. I’m fairly new to woodworking and I’m currently working on a farm table. I glued two of the 4 2×10’s up today and I’m afraid I didn’t use enough glue. I don’t have a jointer so my edges were a little bowed. Or warped, not sure the proper term. My question is , can I screw a little metal bracket on the bottom to keep those two board held together better? I’m trying to keep in mind wood expansion and I will be using proper table top fasteners to let it float. Thanks for the help.
8 replies so far
#1 posted 01-06-2016 01:57 AM
Like this
View Woodknack's profile
11285 posts in 2309 days
#2 posted 01-06-2016 02:03 AM
2691 posts in 1954 days
#3 posted 01-06-2016 08:18 AM
Or, run the glue up through the table saw cutting right down the glue lines. Doing so should give you boards that mate perfectly. But I’d re glue them right away, before they get a chance to bow (or edge set) again. And use plenty of clamps.
View jdh122's profile
990 posts in 2746 days
#4 posted 01-06-2016 10:59 AM
As the others said, you can install metal brackets without causing any structural problems to the table. But I doubt that your original problem was that you used too little glue, rather it was that the boards weren’t straight. The suggestion made by runswithscissors is a good one. For the other two boards to be glued up you might want to consider finding a way to joint the boards – it can be done on a tablesaw or router table (as well as with a hand plane), google will show you how…
-- Jeremy, in the Acadian forests
View Monte Pittman's profile
Monte Pittman
28529 posts in 2267 days
#5 posted 01-06-2016 11:44 AM
First of all, lesson #1. Never assume anything is cut perfect at the lumber yard. I don’t use a lot of construction lumber, but it’s all planed and sized. I am not a fan of lumber yards.
Welcome to Lumberjocks. Hope you post your project when done.
-- Mother Nature created it, I just assemble it.
View rwe2156's profile
2833 posts in 1409 days
#6 posted 01-06-2016 12:18 PM
What scissor said^. Best way w/o a jointer.
#7 posted 01-06-2016 02:48 PM
Thanks for the help guys. I’m going to go with the brackets, I know it isn’t ideal but I’m expecting a baby any day now so my time is limited. Besides, it’s a free table I’m building for my sister so I can always replace the top later down the road when I have a jointer and planer.
View BinghamtonEd's profile
2286 posts in 2298 days
#8 posted 01-06-2016 03:37 PM
Good luck on your table, and even more good luck with the baby! Being a parent is the most rewarding and frustrating gig.
