Forum topic by 3285jeff | posted 01-05-2016 11:04 PM | 1191 views | 0 times favorited | 8 replies | ![]() |
I was looking in the penn state catalog and I ran across a new item they have,,its called a lathe mounted saw and I was wandering if anyone had any experience with this saw,,its a new item and sold out but no reviews,,actually by looking at it it really seems like you could make your own using a hacksaw,,,any comments would help,,thank you |
8 replies so far
#1 posted 01-08-2016 06:53 AM |
I’ve used a saw on my lathe, surprisingly it doesn’t work anywhere near as well as you’d think. With the lathe running the teeth clog. The saw actually cuts faster using it with the lathe off. Maybe they solved that problem with larger teeth or more aggressive set. -- Rick M, http://thewoodknack.blogspot.com/ |
#2 posted 01-08-2016 02:38 PM |
Looks like a solution in search of a problem. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#3 posted 01-08-2016 06:27 PM |
Looks like a parting tool you use from the top to me. -- Kenny, SW VA, Go Hokies!!! |
#4 posted 01-08-2016 08:06 PM |
I tried using a handsaw to cut something while the lathe was turning …. ONCE ! Liked to dang near jerk my arm off ! -- Perform A Random Act Of Kindness Today ... Pay It Forward |
#5 posted 01-08-2016 08:54 PM |
You have to brace it against something. I used a saw I could brace against the tool rest. The goal being an extremely thin parting tool but the tiny teeth on thin blades clog up too quickly if the blade is spinning; or at least they did on mine. -- Rick M, http://thewoodknack.blogspot.com/ |
#6 posted 01-08-2016 09:01 PM |
I’ve used a saw a few times as well.. but they get pretty hot fairly quickly. And I’ve found that hacksaws seem to work a little bit better with less grab. Usually I just use them as Rick mentions, for a really thin parting… and I don’t go all the way through. Just close enough, then I cut it the rest of the way on the band saw. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#7 posted 01-10-2016 05:29 PM |
Tried that as well, = not a good idea. Note to self: next time call a friend. ROFLMAO -- Live to tell the stories, they sound better that way. |
#8 posted 01-11-2016 06:30 PM |
I take standard cork grips for a fishing rod and carefully cut them with a hacksaw blade while on a mandrel on the lathe. I measure what I cut out and replace it with something fancy. |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2110 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4910 |
6698 |
28076 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6237 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
