| Forum topic by xcalibr1 | posted 1215 days ago | 1948 views | 0 times favorited | 18 replies | ![]() |
1215 days ago |
Now that I am getting my shop closer to completion I am being confronted with a bothersome situation and I would like input on what other people do or how they handle it. I dont have any heat in my shop at this point. Im worried about my expensive equipment sitting around in an unheated area with a concrete floor. What is the best way to handle this? Im afraid to take my router table out yet or other equipment like that. Just wanted some input on how other folks handle this in winter time. The garage is built with 2×4 walls and is insulated with R13 in the walls and R-19 in the ceiling. But with no heat it can get very cold in there. I have a propane heater for when Im working in there now but obviously that isnt something that can be ran unattended. I may go with central heat/AC in the future but that is a ways off. Not ready to tackle that yet because of the expense. |
18 replies so far
#1 posted 1215 days ago |
how big is your shop and where do you live -- kosta Virginia Beach, VA http://www.kostasworkshop.blogspot.com/ |
#2 posted 1215 days ago |
Shop area is roughly 19’ x 29’. I live in southern PA just north of the MD border. It can get pretty cold here. Its been down around 32-33 degrees a few times in the past week in the shop with the cold snap. With normal winter temps outside it may only get down around 35-36 in the shop. |
#3 posted 1215 days ago |
Forced air, either natural gas or LP, is the best way to go. A ceiling mounted unit heater using 100% outside air for combustion would be my personal and professional recommendation. -- If at first you don't succeed then maybe skydiving isn't for you. |
#4 posted 1215 days ago |
I agree with the forced air – LP, ceiling mounted. That is what I have in my garage. Knew a HVAC contractor that bought a bunch of apt furnace units for a complex, was able to get one for about $500, and installed it myself, had a local contractor come out, paid $75 to check everything. Good thing, I had the wrong shutoff valve installed and had a small leak. My shop is 24×24. small leak = big boom!. Good thing he checked it. On the note of return air. I have had 2 units in 2 different outbuilding shops that the HVAC contractor just let it cycle. If you pull air from outside, then you are wasting fuel to heat cold air instead of already warm air. I just put 3 filters infront of the return. If you feel like you have to pull air from other than the shop, then pull from the attic, which will be slightly warmer than outside. I think there is one called the bulldog. that is a gas or lp ceiling mounted self contained unit for around $500 made for up to a 3 car garage. |
#5 posted 1215 days ago |
My vote is for a radiant overhead NG heater. Great heat and economical. It’s warm from the floor to the ceiling. I have had forced air in another garage and it took for ever to warm all the way down to the floor unless you leave the thermostat high all the time. Just my opinion though. |
#6 posted 1215 days ago |
My “Workshop in the Woods” is 24’ x 28’, and at 46 degrees north there is plenty of cold weather. For heat, I installed a Reznor 35000 BTU ceiling mounted heater. There is a 250 gallon propane tank just outside the back wall. This heater has the separated combustion feature, thus there is no open flame, and all products of combustion are vented to the outside. I can usually get my shop up into the high 60’s within about 15 minutes. -- "Heaven is North of the Bridge" |
#7 posted 1215 days ago |
I have a “Hotdawg” heater by Moline and I love it. It heats my 2 1/2 car garage no problem and it doesn’t cost an arm and a leg. -- Chip -----------http://www.penmanchip.com-----------------Micah 6:8 |
#8 posted 1215 days ago |
I have in floor heat but it’s too late for that with you concrete floor. A safe and maybe cheaper way with no gas would be an electric hot water system. A small hot water tank and a 2 gallon per minute circulation pump piped to a force flow heater or even an old car radiator with a fan attached should keep it toasty. Total $475 for parts -- Tom From Winnipeg |
#9 posted 1215 days ago |
Are there any good ceiling/wall mounted heaters that run on 110/220 (no gas)? ~the turtle -- ~the turtle |
#10 posted 1215 days ago |
Yes Turtle! Cadet makes a very good heater called “The Hot One” It’s a 240 volt heater. It comes in two versions. A 20 amp and a 30 amp. I purchased the 30 amp model and it puts out a lot of heat and moves a lot of air throughout the shop. I paid $221.00 from A BOY here in Portland Or. A lot depends on the size of your shop and how long each day you spend in the shop. My shop is 21’ X 19’. I can bring the temp of my shop up from high 30s F. to high 60s F. in about a 1/2 hour. My shop is insulated with R19 in the walls and R30 in the ceiling. The heater isn’t as cheap to operate as a gas radiant heater but that wasn’t a good option for me so I went with electric forced air. Another consideration will be the cost of your fuel source. Some areas have fairly cheap electric rates. http://www.cadetco.com/show_product.php?prodid=1012 -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#11 posted 1214 days ago |
Today I finished having heat installed in my garage workshop (gets cold here in Michigan). I put in a Reznor UDAS 75,000 BTU natural gas heater (with a separated heating chamber so that no flames are exposed to the inside air). My garage (which I share with my wife’s car) is 22 ft x 26 ft x 12 ft high. It is great to have a shop that warms up in 10 minutes! I plan on leaving the heat on, since the garage is insulated. Here is the heater… -- DonFaulk0517@gmail.com |
#12 posted 1214 days ago |
I’m just south of you on the MD side of the border and my shop is 13×26. I use a small radiant heater that I got at the Depot. I turn it on about 15 min before heading out to work and it keeps the shop very warm. I often have to turn it off when doing hand work as I generate enough heat on my own. I turn it off when done and have no ill effects from the cold. It is the warmer month you need to worry about with the humidity. Wax your cast iron often and get some kind of cooling in there if you are going to work. My shop is attached to the house and the ambient cooling from the AC keeps it comfortable fortunately. -- The Hand Tool School is Open for Business! Check out my blog and podcast "The Renaissance Woodworker" at www.renaissancewoodworker.com |
#13 posted 1214 days ago |
“On the note of return air. I have had 2 units in 2 different outbuilding shops that the HVAC contractor just let it cycle. If you pull air from outside, then you are wasting fuel to heat cold air instead of already warm air. I just put 3 filters infront of the return. If you feel like you have to pull air from other than the shop, then pull from the attic, which will be slightly warmer than outside.” I was referring to combustion air, not return air. On a unit that uses outside air for combustion you would have a sealed combustion chamber and not have to worry about any dust/dirt working it’s way into your heat exchanger or combustion area for that fact. -- If at first you don't succeed then maybe skydiving isn't for you. |
#14 posted 1214 days ago |
” Are there any good ceiling/wall mounted heaters that run on 110/220 (no gas)? ~the turtle —~the turtle” I’ve got 2 that I am pulling out. Let me know if you’re interested and I’ll get you the Specs… -- Life is a sales job. |
#15 posted 1214 days ago |
hi guys , new here but i like the idea of heating the shop with a hot water tank , but i have something to make it more inexspensive to run and it dehumidifies the space it is in and also can heat your domestic hot water too .
its called a Geyser hot water heat pump .
it can heat alot of hot water and do it for only 400 watts , in stead of 3000 watts in the hot water tank solo.it is 110 volts plug in and conections included . -- Kier Mizuik,Miramichi ,New Brunswick,Canada ://www.heatpumpproducts.com |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2838 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
