Filtration for HVAC
Forum topic by agallant posted 01-05-2016 06:04 PM 599 views 0 times favorited 4 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2855 days
01-05-2016 06:04 PM
View MadMark's profile
MadMark
979 posts in 1421 days
#1 posted 01-05-2016 06:33 PM
Ok, so you’re going to an enclosed system with the garage door closed (or otherwise inside).
You DC exhaust needs to go into a .5 micron bag. The nasty stuff is in the 1-5 micron range. You don’t want that floating in the air. That should reduce the fine dust to a minimum. Just vac up the big chunks into the separator and let the .5 micron bag do the rest. There will be dust. Vacuum often. My AC unit has a ‘filter dirty’ light. Listen when it speaks.
Have fum!
M
View woodwringer's profile
woodwringer
4 posts in 841 days
#2 posted 01-05-2016 06:46 PM
Most minisplits have a woven monofilament filter that is washable. Because they usually have a curved front, I can’t think of an easy way to add more filtration. You might be able to build a box that would cover the entire unit with a filter at the top and an opening at the bottom that seals around the air outlet louvers, but you should be able to get by just washing the filter often.
Woodwringer
-- Woodwringer
View Matt Rogers's profile
Matt Rogers
109 posts in 1938 days
#3 posted 01-06-2016 01:07 AM
I just installed a Mitsubishi minisplit in my shop. I have central dust collection with a cyclone located outside the building, but I don’t always turn it on unless I am doing a lot of work. My unit sucks air in at the top, which is flat. I just placed a piece of cut-to-fit air filter material on the top and it acts as a pre-filter to take most of the dust out of the air before it goes into the unit. I was going to build a box around the unit, but I can’t see it being that much better than placing an extra filter over the inlet. I also have a remote on the wall and shut off the unit when I make a lot of dust – just a press of a button before and after I sand or cut some material. I could set it to only run at night when there is not be dust floating around inside. It has only been operating for a week, so I have yet to see how it will all work out, but it is certainly a lot better than a cold shop. I love having heat.
-- Matt Rogers, http://www.cleanairwoodworks.com and http://www.cleanairyurts.com
View Jim Finn's profile
Jim Finn
2648 posts in 2890 days
#4 posted 01-06-2016 02:34 PM
I have two window units in my dusty shop which is very similar to the, through the wall, unit only a LOT cheaper. I made a simple shelf in front of the air inlet and set a pleated filter in it. Still some dust gets inside the unit so I occasionally clean the coil with coil cleaner from Lowes. My dust collector exhausts outside.
-- Website is https://craftingcouple.com/
