Infinity Lock Miter on 3/4" Maple Ply
« back to Joinery forum
Forum topic by JerryinCreek posted 01-05-2016 04:21 PM 1226 views 1 time favorited 11 replies Add to Favorites Watch
View JerryinCreek's profile
JerryinCreek
211 posts in 1841 days
01-05-2016 04:21 PM
I’m will be building a wall cabinet and planned on joining the corners using the Infinity Lock Miter router bit. I have used this successfully on a few hardwood cabinets but would like to know if anyone has tried this bit and joint on 3/4 ply. I would use an MDF backing board to avoid tear-out. Thanks for your input!
-- Jerry, Johnson Creek, WI "If it was meant to be different it would be."
11 replies so far
View pintodeluxe's profile
pintodeluxe
5660 posts in 2812 days
#1 posted 01-05-2016 06:02 PM
I like locking miter bits on hardwood, but have never been brave enough to try it with plywood.
I’d say cut it in two or three passes, and test it on scraps first.
JerryinCreek
#2 posted 01-05-2016 10:55 PM
OK, thanks. I sent Infinity an email to see if they have any suggestions.
View Paul's profile
Paul
721 posts in 1564 days
#3 posted 01-05-2016 11:28 PM
I’ve used them and consider it more hastle than its worth. Not only do you need to protect the backside from tear out you need to back the edge of the mitre joint itself. I did have success with some veneer I was doing it with but I’d never do it again, too much trial and error, wasted material, and time for my taste.
Paul
JerryinCreek
#4 posted 01-09-2016 05:00 PM
I think I found the answer to my own question. I contacted Infinity and they suggest the lapped miter joint router bits. These look like they will fill the bill nicely! I’ll let everyone know-
4986 posts in 2492 days
#5 posted 01-09-2016 05:06 PM
Those bits (lapped miter) look extremely useful. I have a set on my acquisition list.
View bearkatwood's profile
bearkatwood
1572 posts in 1011 days
#6 posted 01-09-2016 05:42 PM
I used it on my floating stereo shelves and it worked great.
I used dados for the other joinery and the whole setup was very stable.
-- Brian Noel
JerryinCreek
#7 posted 01-09-2016 06:37 PM
Bearkatwood: Great! Planned on using them on the corner miters with dadoed shelves in the middle. Pretty much like your construction. Glad to hear they work well. Thanks!
View ThistleDown's profile
ThistleDown
45 posts in 716 days
#8 posted 07-04-2017 11:00 PM
@bearkatwood, Did you make a video on the build? I checked your YT account but did not see one. I would be interested in real life usage of this as I am thinking of buying a set. But if it is too fiddly I will just use the tried and true way of dowels or biscuits or splines…
I know this is a year old but…
-- My biggest fear is that when I am gone, my wife will sell my tools for what I told her I paid for them.
JerryinCreek
#9 posted 07-04-2017 11:22 PM
I DO find the lock miter can be “fiddly”, but on hardwood they make a great joint. Just need to make several test cuts. Makes a great joint. For plywood – no. I’ve used the lap miter joint router bits very successfully and really like them a lot! Still have to make test cuts but once you learn how to use the they’re great!
View splintergroup's profile
splintergroup
2014 posts in 1222 days
#10 posted 07-05-2017 02:20 PM
I’ve recently been using the rabbeted miter with success on plywoods. It uses a standard blade and after some setup, it’s fast and simple.
#11 posted 07-05-2017 02:45 PM
For you guys that find the lock muter bit a little tedious to set up, consider getting the Lock Miter Master jig from infinity. Below is a pic of my very first lock miter joint (ever) and the very first pass I made. I used the Lock miter master to set it up after carefully following the instructions. You’ll notice the joint is not 100% perfect, but it’s a damn sight closer than it would have been if I hadn’t used the jig.
