Help Designing Coffee Table Legs
Forum topic by RossCapolupo posted 01-05-2016 04:04 PM 1134 views 0 times favorited 14 replies Add to Favorites Watch
View RossCapolupo's profile
RossCapolupo
10 posts in 779 days
01-05-2016 04:04 PM
I am fairly new to woodworking – I have created a couple projects (workbench, dining table) from plans, and have now started designing my own simple projects. I am building a coffee table for my mother, and need help with the construction of the legs. The material I am using is 3/4” reclaimed white oak flooring. She wants the legs to be 4” square and 18” tall (simplified). I want the face grain on all four sides, so to accomplish such large legs with 3/4” stock, my tentative plan is as follows: for each leg, cut four 4×18 face boards, cut the two long edges of each piece to 45 degrees, and biscuit joint all four pieces together as a hollow leg. My questions are:
Is this a legitimate means to construct the required legs from 3/4” stock?
Is the long mitered biscuit joint suitable for the intended purpose?
Will any issues arise from the legs being hollow? Should I use a filler stock? If yes, is there anything I should be aware of to reduce the odds of the filler swelling and breaking/warping the biscuit joints? Would normal 2×4 softwood be acceptable?
Thanks much for your assistance!
Ross Capolupo
14 replies so far
View Yonak's profile
Yonak
986 posts in 1427 days
#1 posted 01-05-2016 04:18 PM
Ross, I’m with you up to the use of the biscuits. It could be tricky to insert the biscuits into the mitred edges .. certainly not impossible but, I believed simple glued edges would be sufficient as long as they’re true.
RossCapolupo
#2 posted 01-05-2016 04:24 PM
Yonak, now that you mention it, I suppose the glue surface will be long grain to long grain… I agree with you! I was using mitered joints in an end grain application, and confused that with this application. Thanks for your help!
View Rick_M's profile (online now)
Rick_M
11112 posts in 2286 days
#3 posted 01-05-2016 04:35 PM
You won’t need a filler other than a plug top and bottom. Biscuits would be fine, I use them on miters. They act as splines and strengthen the joint, they also hold the miters from slipping and make clamping easier.
-- http://thewoodknack.blogspot.com/
View pintodeluxe's profile
pintodeluxe
5568 posts in 2719 days
#4 posted 01-05-2016 05:31 PM
I have done built-up and hollow legs many different ways. The easiest way is to glue layers of lumber together to get your required thickness. Then glue a 1/4” veneer on two sides to cover the jointline. Finally plane the veneer down to about 1/8” thick, or less. Once you ease the edges of your table legs, the jointline will disappear. The downside of course is you use up a lot of 3/4” lumber to make the legs. I usually use this technique for legs 3 inches and under, but it is a sound technique for larger legs too.
Here are some 4” bedposts I made with the laminated technique (I had some swamp oak that would have gone to waste so I used it as filler in the large legs).
Long miters are very difficult to pull off. I have done it with biscuits, and it worked fine, however expect a struggle. Miters don’t really want to be clamped, and you have to convince them otherwise. The biscuits are not really used for strength, but for alignment. The biscuits are helpful in that regard, but honestly it’s not a technique I intend to use again.
My favorite method is to use a locking miter bit on the router table. Then the miter locks together perfectly and holds together even before you add glue. Be sure to mill both sides of the board the same. Ie both sides of board “A” are milled flat on the router table. Both sides of board “B” are milled against the router fence. That way you can close the joints by clamping in only one direction. It really works great. http://lumberjocks.com/reviews/3503
More bedposts, this time with locking miters for my son’s bed.
Rick_M
#5 posted 01-05-2016 08:03 PM
Miters are easier to clamp with clamps made for miters
View jerryminer's profile
jerryminer
888 posts in 1347 days
#6 posted 01-05-2016 08:05 PM
I’ve done hollow, mitered legs and glued-up legs like pinto shows above.
An 18” leg would be simple enough to just glue 4 mitered pieces together, IMHO. I would skip the biscuits. As said above, it’s long-grain-to-long-grain, no reinforcement needed, and biscuits would complicate the assembly, IMO.
No solid fill needed, but think about the apron-to-leg joint. Are you using M&T? I would add some material inside the hollow to accept the tenon in order to get a longer tenon & more glue surface.
RossCapolupo
#7 posted 01-05-2016 08:24 PM
Thanks a ton for everyone’s input.
Pinto – I appreciate the pics and in-depth response; I think I am going to give the lock miter joint a whirl, I just purchased the bit from Rockler… Probably overkill for this application, but I like to learn new techniques. I would normally laminate stock together but have not worked with veneer yet.
Jerry – you bring up a great point. The original design I created is as follows:
This design was based on solid legs, with aprons joined via M&T. However, when we went to the reclaimed lumber yard, my mom found some 4” trim board that she loved and wanted to incorporate. The result was eliminating the aprons and creating four straight legs, with the trim board wrapped around the top of each leg. I have been weighing options for attaching the legs to the top; with the top at only 1-3/8” thick, I am not sure what joint would be beefy enough to do the job. I was actually considering pocket holes on the legs, and screwing into the top – the pocket holes could then be hidden by the trim board. Thoughts?
jerryminer
#8 posted 01-05-2016 08:57 PM
Lock miter is a good choice—simplifies the glue-up, as clamping is needed in only one direction. Be sure to test your set-up on scrap of the exact same thickness as your stock.
I find that leaving a slight (1/32” or so) flat at the edge of the piece makes the lock-miter joint easier to do. You can then ease the corner after glue-up, or plane the face to eliminate the “step” at the corner. YMMV
Make sure you are allowing for wood movement in your design. I don’t know what that in-fill is, but whatever it is, allow for wood movement.
I’m not a big fan of pocket-screws in furniture (although I use them all the time in cabinetry)—- but this is one case where they might work pretty well.
Yonak
#9 posted 01-05-2016 10:48 PM
- jerryminer
True, unless you cut the mitres as in pinto’s example .. then you will have to clamp in both directions. No big deal.
View SirIrb's profile
SirIrb
1239 posts in 1137 days
#10 posted 01-06-2016 12:02 AM
Bizkuts are over rated. Down with Bizkuts and the Norm they rode into town on.
You could spline the joints the full length. Make a saw kerf cut in the face of the miter and then rip a strip of wood to fit in the kerf.
Rick_M
#11 posted 01-06-2016 12:35 AM
Biscuits are easier and faster than ripping splines.
View oldnovice's profile
oldnovice
6550 posts in 3274 days
#12 posted 01-06-2016 12:39 AM
If you use the wood strip spline make sure you orient the grain properly otherwise the spline can split.
As an alternative, use 1/8” plywood, or whatever kerf you cut.
View jbay's profile
jbay
2047 posts in 805 days
#13 posted 01-06-2016 01:28 AM
”I want the face grain on all four sides, so to accomplish such large legs with 3/4” stock, my tentative plan is as follows: for each leg, cut four 4×18 face boards, cut the two long edges of each piece to 45 degrees
Then lay all 4 pcs side by side with edges touching, put 2 or 3 rows of masking tape down each seam, turn all 4 pcs over, glue the miters, fold into a square and tape the last corner tight. Done.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
RossCapolupo
#14 posted 01-06-2016 11:41 AM
Thanks for all the input fellas, this is a great forum.
