Veneer Bar Top
« back to Joinery forum
Forum topic by eebdoow posted 01-05-2016 02:42 PM 784 views 0 times favorited 3 replies Add to Favorites Watch
View eebdoow's profile
eebdoow
53 posts in 2687 days
01-05-2016 02:42 PM
Hello Jocks,
I am in the process of building a basement bar/kitchen. The bar top is going to be 12’ X 8’ in the shape of an L and the width is going to be around 15”-16”.
I plan to use black walnut as my bar top and wanted to ask the group how thick it should be? I plan on re-sawing the walnut and thought 1/32” veneer would be to thin for a bar top, yet I don’t want to go too thick and have movement issues. I plan on using 1 layer of 3/4” baltic birch and gluing the walnut onto another 1/2” baltic birch.
If I glued the walnut to the 1/2” birch ply and used screws underneath do you think that would stop any movement? I have quite a bit of 12/4 black walnut so i can go as thin or thick as I need, but don’t want waste the walnut by going to thick. Thanks folks,
Ebb
-- In an age of universal deceit, telling the truth is a revolutionary act -George Orwell
3 replies so far
View MNgary's profile
MNgary
301 posts in 2445 days
#1 posted 01-05-2016 09:15 PM
My understanding of wood movement in response to change in humidity is the length and the width changes are not related to thickness of the board (veneer), only to overall length (for change in length) and overall width (for change in width). However, I have been told when the thickness exceeds 1-1/2 inches the lateral and longitudinal changes due to moisture content behave differently and thickness has to be considerred.
-- I dream of a world where a duck can cross the road and no one asks why.
View levan's profile
levan
472 posts in 3007 days
#2 posted 01-05-2016 09:54 PM
First I think screwing up into 1/2” plywood doesn’t give a screw much to hang on to. Probably need to reverse the order. If I had plenty of walnut, I would consider making a solid top. A lot less work and easy to refinish. Being a bar/kitchen it will probably get some dings.
just my opinion
best wishes lynn
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View Hammerthumb's profile
Hammerthumb
2853 posts in 2003 days
#3 posted 01-05-2016 11:02 PM
You should not have movement issue with 1/16” veneer over plywood. I feel that 1/32” is a little thin for a bar top as it will limit how many times it can be refinished due to wear.
-- Paul, Las Vegas
