Fire place mantel - hollow version to fit over warped original
Forum topic by The__Dude posted 01-05-2016 04:04 AM 1401 views 0 times favorited 9 replies Add to Favorites Watch
View The__Dude's profile
The__Dude
125 posts in 1085 days
01-05-2016 04:04 AM
Topic tags/keywords: mantel rough box
Current fireplace has a 3” thick slab of wood. It is rough cut and warped and twisted.
I was thinking of building a “box” that would slide over the warped mantel.
I would plane/shim the existing mantel to create a flat level surface for attachment.
See my sketches.
I was thinking of purchasing rough saw 1” stock. Hand plane to give it a rustic look.
9 replies so far
View clin's profile
clin
849 posts in 1018 days
#1 posted 01-05-2016 04:21 AM
It’s common to mount a mantle using a cleat. Seems to me like your going to turn your old mantle into a cleat. Should work fine.
Though I’d make sure the old mantel is securely mounted. Depending on how it is mounted, it could be better to remove it, and mount a cleat specific for the job. But if the old one is secure, sounds like a great idea to me.
-- Clin
The__Dude
#2 posted 01-05-2016 01:26 PM
It is secured and there is rough cut stone cemented around it.
Also was planning on floating the box so I can clear the various protrusions of rock.
Now I need to figure out how to join rough sawn boards.
I supposed to need to hand plate the joint areas flat.
View Kazooman's profile
Kazooman
1024 posts in 1974 days
#3 posted 01-05-2016 02:54 PM
We did just what you are suggesting to our fireplace when we remodeled. The exising mantel was a rough sawn barn beam. We capped it with a custom made maple box to give it a more modern look and to match the new hardwood flooring. The fireplace is made of very large stones so there was a very uneven edge. The box was simply scribed and shaped to fit the surface. The joint was set in mortar that matches the original and the seam disappeared.
The__Dude
#4 posted 02-09-2016 04:01 AM
I have the box all built and I am now applying the finish.
Will post some before/after when I mount it.
View gfadvm's profile
gfadvm
14940 posts in 2712 days
#5 posted 02-11-2016 01:05 AM
That is exactly why I am hesitant to cut 3” thick mantle beams: they always seem to warp. twist, and crack. Your fix looks like a winner.
The__Dude
#6 posted 02-13-2016 04:05 PM
This was my first project.
The__Dude
#7 posted 02-14-2016 08:36 PM
Kazooman
#8 posted 02-14-2016 09:02 PM
Hey Dude!
That turned out really great. Especially for a first project. You should be very proud of the result.
The__Dude
#9 posted 02-18-2016 12:33 AM
I just used some coats of wipe on poly.
The color is the natural wood
