JJ-6CS Gibs...the right ones?
Forum topic by TadMcD posted 01-04-2016 08:47 PM 460 views 0 times favorited 1 reply Add to Favorites Watch
View TadMcD's profile
TadMcD
1 post in 842 days
01-04-2016 08:47 PM
Hi. Noobie here.
I got a Jet JJ-6CS and took it apart to clean the gunk and junk and found the two gibs (how do you pronounce that?) to be galled and sort of icky so I ordered two new ones from ereplacement.
When I got the replacement parts, they were/are different than the OEM gibs I found in the planer; the “new” parts had a sort of “v” groove in one side while the original parts were/are solid pieces of [steel?]. Also, all the gibs have what looks like the beginning of where someone started to drill a hole in one end, like maybe where one of the hex screws fit?
Anyone have any ideas about the efficacy of the new parts and/or can ‘splain to me this whole hole business?
[Oh, I’m planning to lubricate the ways prior to reassembly with spray DRY silicone. Thoughts?]
Thanks in advance.
1 reply so far
View MrUnix's profile
MrUnix
6609 posts in 2168 days
#1 posted 01-04-2016 09:06 PM
Can’t help with the replacement parts, but I would suggest you use something else besides a silicone based lubricant on that machine. Dry lube with teflon (PTFE) or even paraffin wax would be a better choice.
