What to make from a bench saw.
Forum topic by 716 posted 01-04-2016 05:37 PM 744 views 0 times favorited 13 replies Add to Favorites Watch
View 716's profile
716
502 posts in 909 days
01-04-2016 05:37 PM
I have a bench saw pictured below. It has a surprisingly good aligning fence for this kind of saws, It locks square each time. However it is of limited use mainly due to its size and the absence of any dust collection. There are dozens of these saws on craigslist so I do not hold my breath that I would be able to sell it for more than the blade it comes with.
Any ideas for a second life for this saw? An obvious choice is a disc sander as there are sand discs designed to be used on table saws. Too much dust though.
Anything else ?
-- It's nice!
13 replies so far
View MrUnix's profile
MrUnix
6695 posts in 2192 days
#1 posted 01-04-2016 05:43 PM
I have a similar type saw (plastic case, universal screamer motor C-man thing) that had a fried motor (surprise!). Turned it into a dedicated router table :)
But since yours is working, that might not be the best use.
View 716's profile
716
#2 posted 01-04-2016 07:09 PM
If yo mange to use the tilting mechanism in your router table that would open a whole new set of possibilities.
-- It's nice!
View conifur's profile
conifur
955 posts in 1145 days
#3 posted 01-04-2016 07:28 PM
Possible a disc sander if you can get a 10”’ disc with a 5/8 arbor, but the rpm maybe to fast for that, not sure about that.
View knotscott's profile
knotscott
8005 posts in 3368 days
#4 posted 01-04-2016 08:27 PM
Sanding discs don’t work out all that well running at TS speeds of 4K rpms, and tend to burn and glaze the sandpaper quickly. Most sanders run at a fraction of that speed. If you could gear it down it might work ok as a sander.
View 716's profile
716
#5 posted 01-04-2016 08:47 PM
The blade speed is actually 5300 rpm on these saws. However what do you think about combining the saw + sand disc with this:
-- It's nice!
View TheGreatJon's profile
TheGreatJon
337 posts in 1226 days
#6 posted 01-04-2016 08:48 PM
I’m not sure what kind of projects you typically take on, but if you do lots of repetitive cuts it’s not a bad idea to keep it as a TS and just use it for dados or certain angled cuts or some other setup that takes time to change on your main saw.
-- This is not the signature line you are looking for.
MrUnix
#7 posted 01-04-2016 08:59 PM
I have never tried using one of those speed controls on the saw, but it is a brush type motor, so it may be possible. The problem is that you will have to run it considerably slower than it was designed for, so not only will the motors internal cooling fan be unable to push enough air to keep it cool, but you will also lose a lot of power/torque. Heat is what will tear those motors up (due to the plastic motor housing), and those things aren’t really all that powerful to begin with :)
I eventually did what Jon suggested.. I had originally turned mine into a dedicated router table, but I wound up running across an identical saw someone was giving away for free on CL. They had backed into it with their car and smashed up the stand and broke the plastic cabinet – but the saw ran fine. I swapped motors and now in addition to being used as a router table, I also use it as a dedicated cross cut saw (with a sled).
View Don W's profile
Don W
18707 posts in 2560 days
#8 posted 01-04-2016 09:14 PM
I put a metal cut off wheel in something similar. Of course I had a use for a metal cut off wheel at the time.
View dhazelton's profile
dhazelton
2766 posts in 2289 days
#9 posted 01-04-2016 09:45 PM
If you ever install flooring in a second floor you will be glad you have that. If you ever have to do a job at a friends or customers home you will be glad you have that. If you ever cut nasty dusty material that you don’t want around your main saw you will be glad you have that. I would take the legs off and put it up on the shelf.
woodbutcherbynight
4497 posts in 2402 days
#10 posted 01-05-2016 04:09 AM
If you ever install flooring in a second floor you will be glad you have that. If you ever have to do a job at a friends or customers home you will be glad you have that. If you ever cut nasty dusty material that you don t want around your main saw you will be glad you have that. I would take the legs off and put it up on the shelf.
- dhazelton
I use mine for such occasional away from the house projects. Also you can put the bade in backwards and cut vinyl siding without tearing it up. Had to make a special drawer to store it on its side to save space.
runswithscissors
2750 posts in 2018 days
#11 posted 01-06-2016 01:54 AM
I would hesitate to use a light duty saw like that for dados. For one thing, the arbor is probably too short, plus you would have to make an appropriate insert, and inserts are problematic on that type of saw.
View FirehouseWoodworking's profile
706 posts in 3266 days
#12 posted 01-06-2016 03:07 AM
I am in a similar situation with a small saw such as that one. I plan on turning it into a dedicated finger jointing saw. I will build a jig and dedicate a blade so that the only adjustment I need to make will be to the blade height, depending upon the material thickness.
I like finger joints for building strong boxes. Having a dedicated saw, the set up takes no time.
Haven’t started on the jig yet, but that’s the plan.
Cheers!
-- Dave; Lansing, Kansas
View Woodknack's profile
Woodknack
11600 posts in 2373 days
#13 posted 01-06-2016 04:04 AM
- FirehouseWoodworking
Whoa, I like that idea.
