Painting a laminate countertop?
Forum topic by AAANDRRREW posted 01-04-2016 02:50 PM 652 views 0 times favorited 12 replies Add to Favorites Watch
View AAANDRRREW's profile
AAANDRRREW
210 posts in 1376 days
01-04-2016 02:50 PM
Forgive me if I am straying too far away from traditional woodworking/finishing, but I am curious if anyone has ever painted a laminate countertop – either with DIY style products or the kits like rustoleum makes.
I have some kitchen countertops that are kind of ugly. The wife found a few blogs where the blogger scuffed up the finished, used either homemade chalk paint (some latex paint w/ plaster of paris) and coated it with poly, over the counter chalk paint and poly, or the rustoluem countertop paint/renewal system.
The big rustoleum kit has chips and a 2 part finish and produces a faux granite look. It looks like a lot of work and can be pricey (over $100). rustoleum also makes a countertop paint that is oil based and claims to be one-stop-shop…which gives me reservations about durability and such.
The DIY chalk paint and poly also gives me some reservations – I don’t have a problem sanding and painting, but then it comes to the finish…. What I understand about poly is that the first coat seals the wood and the further coats build up a nice protective finish – but on a laminate countertop, there won’t be any “sealing”, which worries me about adhesion. Also, I am guessing poly will NOT be as durable as laminate, so try as we will, I worry there WILL be nicks, gouges, scratches because our island in our kitchen is for eating family dinner, but it is also used for 101 other things as well.
Thoughts?
12 replies so far
View Kazooman's profile
Kazooman
1240 posts in 2156 days
#1 posted 01-04-2016 03:22 PM
Why not consider new laminate? If the existing material is sound, you could rough it up and install new material on top of it. If you would need to remove it that is a much bigger problem. Since you are considering paint, I assume the existing laminate is solid.
View dhazelton's profile
dhazelton
2794 posts in 2500 days
#2 posted 01-04-2016 03:40 PM
You can pretty much paint anything if it’s degreased and scuffed well. How long it will look good is another question. The kit’s do show beautiful transformations but I don’t know if the finish is durable. Another option (if you own the home) is ceramic tile. Might look a bit more modern.
117340 posts in 3781 days
#3 posted 01-04-2016 04:06 PM
Depending on how big of area you’re talking about installing new laminate may be about the same price plus the cost of a trim router if you don’t have one HF sells them fairly cheap. there are so many designs you can get in new lamante and it will hold up better than any paint.
https://www.youtube.com/watch?v=ZgWCMDA_G0M
AAANDRRREW
#4 posted 01-04-2016 04:25 PM
Yes, my countertop is is good shape and is only 7 years old – I just never liked the color of it.
I will investigate the re-laminating, but I am guessing I will have difficulty dealing with the curved edges (they aren’t all 90’s) and the backsplash area, which I don’t think its cut, its curved inward (if that makes sense).
I was really hoping someone would say “yeah, just scuff it up, paint it and throw some poly on it’ll work great” haha….
View conifur's profile
conifur
955 posts in 1356 days
#5 posted 01-04-2016 04:29 PM
As a residential remodeler who specialized in tile for 20+ years I have seen tile in bath rooms that was redone with an epoxy paint, done professionally, and it does not hold up. With counter tops what you want todo IMHO is a waste of time, for any longevity, with the wear and tare they get.
View HokieKen's profile (online now)
HokieKen
7144 posts in 1342 days
#6 posted 01-04-2016 04:48 PM
I will investigate the re-laminating, but I am guessing I will have difficulty dealing with the curved edges (they aren t all 90 s) and the backsplash area, which I don t think its cut, its curved inward (if that makes sense).
I was really hoping someone would say “yeah, just scuff it up, paint it and throw some poly on it ll work great” haha….
- AAANDRRREW
Yeah, just scuff it up, paint it and throw some poly on it’ll work great.
No, not really ;) I have seen a bathroom vanity that someone used one of the diy kits to paint. It did look great right after it was done but definitely hasn’t held up. It doesn’t look horrible but it’s definitely not something I’d want in my kitchen. I’d come down in the camp of relaminating if you can deal with the curves and bevels.
-- Kenny, SW VA, Go Hokies!!!
View pjones46's profile
pjones46
1001 posts in 2847 days
#7 posted 01-04-2016 04:55 PM
I have re-done a number of boat counter tops by removing the old laminate with a standard cheap household iron, no flame, to heat up the contact cement which then allows you to peal the old laminate off. Once off, you can reapply fresh contact cement and new laminate.
-- Respectfully, Paul
View Bill White's profile
Bill White
5128 posts in 4164 days
#8 posted 01-04-2016 06:23 PM
Just send me the money and chalk it up to experience. :)
IMO that stuff is a waste of time.
Bill
-- bill@magraphics.us
dhazelton
#9 posted 01-04-2016 07:06 PM
“and the backsplash area, which I don’t think its cut, its curved inward (if that makes sense)”
So it’s a preformed counter with integrated backsplash from HD or Lowes? Just pull the whole thing up and replace it. Yes, it’s a lot of work but not that expensive if it’s just like a standard ell.
AAANDRRREW
#10 posted 01-04-2016 07:19 PM
Yeah, I’m thinking it’s preformed – not sure if its from a big box store, but I’m sure its as cheap as humanly possible – the house isn’t a spec home or pre-built, but the builder built all the homes in my area – there are like roughly 5 different models you can choose and customize. You basically go meet with him, he shows you his plans, you pick and choose things to customize and he builds it. In retrospect, I wish I didn’t buy the place (I’m the 2nd owner), but live and learn…
View JoeinGa's profile
JoeinGa
7739 posts in 2211 days
#11 posted 01-04-2016 09:19 PM
I was really hoping someone would say ”... haha….
- AAANDRRREW
“Yeah, just scuff it up, paint it and throw some poly on it. It’ll work great”
It will look fantastic from where I’m sitting (I’m in Georgia, where are you again?) LOL
View MrUnix's profile
MrUnix
7053 posts in 2403 days
#12 posted 01-04-2016 09:24 PM
I’ve seen all sorts of nice ‘faux’ countertops done with paint and then covered with a clear epoxy coating. Mostly for creating a granite look. A quick google will turn up quite a few how-to’s, discussions and videos of the process. I would just replace or re-laminate the top, but a lot of folks have been happy with the results from using epoxy. YMMV.
