Thien baffle dust seperator
Forum topic by Joel_B posted 01-04-2016 03:58 AM 2566 views 1 time favorited 21 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
354 posts in 1620 days
01-04-2016 03:58 AM
I am planning to improve my dust collection from my current shop vac to a modified HF dust collector.
What is the best solution for the Thien baffle? I don’t care about buy vs build or what is the cheapest. I am more interested in what works the best and requires the least maintenance.
I am also wondering about pros / cons of a Rubbermaid 32 gallon Brute trash can vs a 30 gallon metal can.
Thanks
-- Joel, Encinitas, CA
21 replies so far
View Harry's profile
Harry
80 posts in 1419 days
#1 posted 01-04-2016 04:38 AM
I used this with the Thien internal baffle and you can visually see when it’s time to empty.
Harry
-- Harry - Professional amateur
Joel_B
#2 posted 01-04-2016 04:48 AM
I used this with the Thien internal baffle and you can visually see when it s time to empty.
Harry
- measure2wice
That would be handy.
Thanks
View JeffP's profile
JeffP
573 posts in 1631 days
#3 posted 01-04-2016 02:28 PM
I have had very good results with a metal trash can.
I have heard some people say that their attempts with rubber trash cans resulted in the can collapsing under the stress of the vacuum. Seems to depend on the brand/style/material of the non-metal ones as to whether or not they can handle the suction.
Thein is not necessary in my experience…just a simple PVC elbow carefully positioned to shoot the incoming air stream along the perimeter of the can does a good job of separating all of the visible dust/chips from the air before it gets to the DC.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View Bill7255's profile
Bill7255
428 posts in 2524 days
#4 posted 01-04-2016 02:39 PM
If you want optimum performance a cyclone would be the best. Especially if you have it hooked up to sanders. I have a 3hp Jet DC hooked up to the large eBay cyclone and vent outside. I am very happy as there is nothing outside at the exhaust and I do run a drum sander. I don’t know what cyclone would work with the HF DC.
-- Bill R
View mds2's profile
mds2
310 posts in 2183 days
#5 posted 01-04-2016 02:46 PM
I have my thein baffle on rubbermade trash can and I have not had any problems at all. In fact it works great. I only have a Jet DC650 though.
View CharlesA's profile
CharlesA
3359 posts in 2037 days
#6 posted 01-04-2016 02:58 PM
I found on the CL in my area that 55 gallon plastic drums with lids can be had with some frequency and pretty cheap—they're going for $10 in Louisville right now. That’s what I ended up using
HillbillyShooter
5811 posts in 2531 days
#7 posted 01-04-2016 03:10 PM
This is my solution: http://lumberjocks.com/projects/102418
It has worked well with no problems. I’ve been pleased. The only drawback back is a noticeable loss of suction—I’ve seen estimates of up to 40%. However, I knew this going in and made a conscious decision to accept the drawback as being outweighed by the advantages.
CharlesA
#8 posted 01-04-2016 03:13 PM
I didn’t measure it, but I don’t think I’ve suffered a substantial loss of suction with mine. I’m sure I’ve lost some, but I would think more like 10%
Harry
#9 posted 01-04-2016 03:48 PM
I think the suction is better after my modification. I have an old Delta that is about the same as the HF unit that had 4” Y connected to a 6” inlet. There was also an internal reducer that I cut out so it was 6”. That 6” inlet went to the can with a 4” going out. I also think the Wynn filter REALLY helps with air flow. I have emptied the can twice and only have a handful of very fine dust in the bag after the filter.
Joel_B
#10 posted 01-04-2016 04:07 PM
Would like to hear more details about the Thien baffle itself.
There are some plastic ones you can buy for around $30 but the reviews seem to indicate they need additional modifying to work well. So it seems building one would be best. I see lots of designs to do this, but wonder if some designs that are better than others. I guess the plastic ones would be lighter and easier to lift off if that is a good thing.
CharlesA
#11 posted 01-04-2016 04:20 PM
Joel,
You can buy some plastic separators, but I don’t think you can purchase a thien baffle. All of us have made them from the basic design you can find at: http://www.jpthien.com/cy.htm
View WoodES's profile
WoodES
135 posts in 1930 days
#12 posted 01-05-2016 04:41 AM
Check out the Sketchup warehouse for plans. Scale to fit your application.
I used this a basis for a separator for 6” duct and large barrel.
https://3dwarehouse.sketchup.com/model.html?id=b6e3c012f58403af64480d86c49e1de1
Mine works well but can bog down under the longer run and heavy chip load from the planner or joiner. I plan to test a smaller trash can separator at the tool in the future.
View joey502's profile
joey502
544 posts in 1757 days
#13 posted 01-05-2016 12:26 PM
If you are willing to buy the super dust deputy works very well for me. I have it mounted on a 30 gallon plastic drum with removable top. The DC is wall mounted directly above the separator.
I have not built or used the Thein baffle linked above but i can not ever remember seeing a bad word about it. Everyone that has built one seems to be very happy with the results.
View TTF's profile
TTF
154 posts in 3417 days
#14 posted 01-06-2016 05:32 AM
I’ve benn running an HF dust collector with thien baffle for about 2 years and I love it. I will get some more detailed pictures of my set up over the next few days.
It was a very easy build. I took the collar and put the baffle plate below cone and put a plate on the top for the exit duct – that’s about it.
I started with a rubbermaid can and then got rid of it. I couldn’t get it to seal well. I cut the top off a metal can and use sheet metal screws to mount it. There is a 1/4” weatherstrip on top of the can.
This thing pulls almost all the dust, all the time. I have no filter. I duct the air out from the motor to outside my shop. I think there is a cup-full of dust on the gravel below the exit vent after emptying the full can a couple dozen times.
For my set-up – 600 SF shop with 4” under-floor ducting, located in Portland Oregon (mild cold in the winter), and a wood-stove heated shop with replacement air intake that comes up right behind the stove – there is zero need or motivation to have a filter. Just more money and maintenance. Also, my exit duct is 15 ft of 5” mylar coil heating duct with a fiberglass insulation sleeve – it acts a good sound muffler. My neighbors are about 50 ft away, and never any complaints about noise.
One day when the 2HP HF motor dies, I’ll just go buy a new one. Or maybe find some big blower motor on CL – it doesn’t really matter as long as I get the CFM I need.
-- Troy | http://tf-workshop.com | The more I see nature, the more I am amazed at the Creator. - Louis Pasteur
Joel_B
#15 posted 01-08-2016 04:06 PM
I have been waffling on this after looking at using an Oneida Dust Deputy and a 5 gallon bucket with my Rigid shop vac. But when I look at the specs on the Rigid shop vac it says it is 6HP and 168 cfm. Compared the HF DC which is 2HP and 1550 cfm. Why does the HF DC have much higher CFM at lower HP? I am guessing its just the way each one is designed and the HF has larger spaces so less restriction. The Rigid does seem to pick up dust pretty well but HF must be much better with the cfm being much higher?
After looking more at the Rigid specs it says 11 Amps which would be 1.75 HP assuming 100% efficiency. So I am not sure what they mean by “6HP peak”
