| Forum topic by bent | posted 1243 days ago | 3067 views | 6 times favorited | 21 replies | ![]() |
1243 days ago |
this joint is on a drawer front on a small antique piece. i’ve never seen one quite like it before. at first i thought it was a just drilled out and a dowel was driven it. but it’s actually a round through tenon from the side of the drawer face. i can only imagine what a pain this must have been to make. any ideas what it’s called, or how it’s made?
21 replies so far
#1 posted 1243 days ago |
Antique router? I’d bet it was made with a rotary tool of some type. -- Dan, Sterling Alaska, Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes! |
#2 posted 1243 days ago |
Don’t know what it would be called. I would cut the drawer sides first then mark the front. You could template rout the drawer front but your template would need to match the drawer side exactly. I’m not sure how I would cut the drawer side. A router bit could hog out most of the waste but it wouldn’t be able to get into the sharp points between circles. Chisel the rest? Are you going to use this joint? Let us know how it turns out. -- Brain the size of a planet and they have me parking cars. |
#3 posted 1243 days ago |
Bears ear joint?? -- "I don't cut wood. I machine it!" G.M. The wood machinest |
#4 posted 1243 days ago |
I have a round tenon cutter that I use to make dowels. That would make the drawer front real easy with a simple indexing fixture. (Tenon cutter has 870 rpm max so you would need a tall drill press.) Round mortises in drawer side could be done with forstner bit. Cutting the rounded humps on the drawer sides could be done with a point cutting roundover router bit. (I have one from Whiteside for routing signs.) Another indexing fixture required. Aligning the mortises and routed humps on drawer side would need a very accurate fixture. Steve. |
#5 posted 1243 days ago |
Hi Bent, I have a chest of drawers that utilizes the same joint. I have been asking for years how it was done. Let me know if you try and how it comes out. |
#6 posted 1243 days ago |
It’s called a pin and crescent joint. I have been waiting for the right project to come along to use it. The problem is that the drawer height has to be divisible by the number of pins and crescents. -- Gary - Never pass up the opportunity to make a mistake look like you planned it that way - Tyler, TX |
#7 posted 1243 days ago |
That is a Knapp joint. There was a machine made just for those. It wasn’t in popular use for all that long so it may help in dating the piece. http://www.antiqueweb.com/articles/antique_knapp_joint_dovetail.html -- - CaseMan - |
#8 posted 1243 days ago |
Here’s a router jig/template to reproduce the joints. http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=886-459&LARGEVIEW=ON&CARTID=200402157660284040--1 -- - CaseMan - |
#9 posted 1243 days ago |
My brother has a beautiful rosewood chest made with these joints. When I looked it up a couple of years ago, I found that it is a machine-made joint, and is known by a number of names: “Pin and Crescent”, “Crescent”, “Pin and Cove”, “Pin and Scallop”, “Half Moon”, “Knapp” – and likely others. The most common name seems to be the “Pin and Crescent” as noted by GaryK. I also discovered that “Woodworker’s Supply, Inc.” has a couple of jigs for making them. -- Dave O. |
#10 posted 1243 days ago |
Boy I learned a lot. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#11 posted 1243 days ago |
yeah, me too! thanks for all the information guys. |
#12 posted 1243 days ago |
cool :) -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
#13 posted 1243 days ago |
This was most illuminating…..As Jim said…I learned alot about a joint I had not seen very much…and I certainly never had a name for it before…Thanks all for the great lesson. -- Woodworking.....My small slice of heaven! |
#14 posted 1243 days ago |
look ma, i learned a new thing! oh wait, i think i just forgot how to blink in order to make room :( -- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves. |
#15 posted 1243 days ago |
Great thread. There’s always something new to learn. -- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
