What's it?!
Forum topic by Randy_ATX posted 01-04-2016 01:02 AM 709 views 0 times favorited 5 replies Add to Favorites Watch
View Randy_ATX's profile
Randy_ATX
878 posts in 2407 days
01-04-2016 01:02 AM
A buddy inherited a couple of these (and many other items) from his father-in-law. It’s obviously a nice rail and type of clamp system, but I’ve never seen one like this, and am stumped on how it would be put into use. There are no holes drilled into the track to fasten it to say a benchtop or similar. Can anyone ID this and give a description of how it would be used? Thanks!
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
5 replies so far
View shampeon's profile
shampeon
1775 posts in 2148 days
#1 posted 01-04-2016 01:13 AM
I’m pretty sure you drill your own holes after cutting a dado in whatever flat surface you’re mounting it to. A lot of t-track isn’t predrilled.
Then you just use them as cam clamps for holding things down.
View gfadvm's profile
gfadvm
14940 posts in 2655 days
#2 posted 01-04-2016 01:26 AM
I have a similar set up (shop made) to straight edge rough cut lumber. The red strip is clamped to the board so you have a straight surface to run along the tablesaw fence. You don’t sat how long it is so I may be way off base.
Randy_ATX
#3 posted 01-04-2016 01:30 AM
Thanks for the replies so far – the aluminum railing is about 7 or 8 feet long and about 4 or 5 inches wide.
gfadvm
#4 posted 01-04-2016 01:42 AM
That sound like my set up for “straightening” lumber.
View MadMark's profile
MadMark
979 posts in 1418 days
#5 posted 01-04-2016 11:13 PM
Panel cutting clamp for hand circular saw.
M
