Any thoughts on Grizzlys new 15 inch planer (G0815)?
Forum topic by EMWW posted 01-03-2016 08:51 PM 7058 views 0 times favorited 11 replies Add to Favorites Watch
View EMWW's profile
EMWW
23 posts in 1032 days
01-03-2016 08:51 PM
Topic tags/keywords: 15 inch planer planer
I was looking at my new Grizzly catalog and saw they had a new 15 inch planer at a lower price than the regular ones. It turns out that it has no stand. You either have to buy their stand for it or make one which is no problem. Instead of the table going up or down like a normal planer that size the top with the motor goes up and down. I think this may be useful if I build infeed and outfeed support so that it will work on all thicknesses of lumber. I am just not sure if this might be any good and wanted to ask people who know more about these things than I do. Any thoughts would be helpful or if any of you have used planers like this before (excluding the benchtop ones that follow the same principle). Thanks in advance and I will be looking forward on the feedback.
11 replies so far
View AZWoody's profile
AZWoody
1396 posts in 1343 days
#1 posted 01-03-2016 09:01 PM
Looks interesting. I didn’t look at the planers yet in my new catalog. That would actually open up the doors to a lot of the hobbyists who need something better than a lunchbox but do not have the space.
What’s the horsepower on that? It looks like universal motor, which is nice to have and will help the noise reduction a lot. If the dust collection is like their larger ones, and it looks like it is, as long as there is a decent cfm flow, it will be a fairly clean machine.
The only thing bad I could see is if it’s 220v instead of 110. Something like that would need the higher hp but by it’s design would see more work in a garage or basement shop and might not have the power reqs needed.
View EMWW's profile
EMWW
#2 posted 01-03-2016 09:09 PM
It is 3 hp 230 volt 18 amps. The motor is induction like on a good table saw. (induction motors typically are less noisy) The dust collection looks pretty good but since the PA showroom closed I will not be able to look at it before buying it. I actually prefer it to be 240 volt because I can use thinner wire if I decide to buy it. ( when you double the voltage the amps are cut in half) EX: 10 amps 120 volt = 5 amps 240 volt
View MrUnix's profile
MrUnix
6889 posts in 2318 days
#3 posted 01-03-2016 09:12 PM
Looks like a pretty close clone of the old Delta Invecta’s (but with more plastic bits):
Should be a standard TEFC based on the fan enclosure on the end. Much quieter than a universal screamer on the lunchboxes.
PS: Those Deltas can be found fairly often for way cheaper than the new imported clones :)
AZWoody
#4 posted 01-03-2016 09:56 PM
Sorry, I meant to say induction. I was typing in a hurry before I had to run out the door.
I would prefer 240 as well but I wondered if a two horsepower would work on a 15 inch planer. For something portable, 110 might seem a better option.
What is the weight on that?
View EMWW's profile
EMWW
#5 posted 01-03-2016 10:00 PM
The weight is about 330 pounds. I think for 15 inches 2 hp might be just a little underpowered but might work for really light cuts or narrow boards.
View jar944's profile
jar944
127 posts in 1557 days
#6 posted 01-04-2016 01:46 AM
Looks like they brought the old 1021 back.
View Cbrodersen's profile
Cbrodersen
2 posts in 793 days
#7 posted 07-21-2016 08:28 PM
I just bought the Grizzly G0815. Here’s my review that I posted on the Grizzly website (with some additions) -
I took a chance buying the brand-new Grizzly G0815 planer, and I’m glad I did. It replaces my 40-year-old Parks 12” planer, and the Grizzly exceeds the Parks in every department—quality of cut, noise and vibration levels, and dust collection. There is one odd design feature about the Grizzly—no bed rollers—but this is actually an advantage, because it almost guarantees no snipe (out-of-adjustment bed rollers are usually the culprit). Because I always surface one side before sending the piece through the planer, the rollers won’t be missed.
The anti-kickback fingers are undoubtedly a good safety feature, but they take some getting used to (the Parks didn’t have them). It’s hard to see the in-feed roller, and therefore difficult to gauge where you are when setting the machine for the first pass.
A few less-than-ideal details: the chain and sprocket drive for the headstock lifting mechanism is completely enclosed and can’t be accessed for lubrication unless you unbolt the machine and lift it off the stand. Also, the dust hood port points to the left; as luck would have it, I needed it to exit on the right, so in order to reverse the hood, I had to cut off the existing mounting flange, make a new one out of 1/16” alum. and epoxy it to other side.
The machine weighs 340 lbs—unless you have a fork lift or cherry picker at your disposal, you’ll need (4) guys to lift on to the stand.
View BorkBob's profile
BorkBob
127 posts in 2812 days
#8 posted 07-21-2016 11:18 PM
I have the same planer but it’s yellow and green and labeled “Woodtek”. It came with a stand but I mounted it on a repurposed TV console cabinet. I think I’ve had it about 8 yrs. I remember it was $600 delivered.
Absolutely no complaints. It has bed rollers but I don’t use them. Also has infeed and outfeed rollers and I use those. I used some 1.25” plastic pipe and some 6/4 lumber to make a frame over the planer to hold the stock while planing. The pipe fits into the “tubes” and over the height adjustment screws.
I am debating ordering a shelix head for it or selling it and buying a Griz with the head already installed.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
Cbrodersen
2 posts in 793 days
#9 posted 07-21-2016 11:45 PM
I asked the Grizzly folks if the G0815 would be available with a Shelix head, and they said, “not in the immediate future”.
View RogerM's profile
RogerM
798 posts in 2518 days
#10 posted 07-21-2016 11:50 PM
Looks almost identical to the Delta DC 380 which is an outstanding performer.
-- Roger M, Aiken, SC
View Tracy71's profile
Tracy71
24 posts in 219 days
#11 posted 02-16-2018 01:54 PM
Well the planer has been out a while, any updated reviews, opinions, warnings etc. thinking about buying one but can’t find any updated reviews.
