What's the difference between a jointer/planer and a jointer?
Forum topic by tolmeda posted 01-21-2010 07:38 AM 8814 views 0 times favorited 10 replies Add to Favorites Watch
View tolmeda's profile
tolmeda
11 posts in 3110 days
01-21-2010 07:38 AM
Topic tags/keywords: jointer planer
I’ve got my eye on the Ridgid 6 1/8” Jointer/Planer (JP0610) at HD but I don’t understand why they give it the dual label. I read through the manual and it seems to me it functions in much the same way as every other jointer of that style. There was nothing in there that showed a planer-type configuration.
Granted, I’m a novice, but I was under the impression that a jointer made two adjoining sides meet at a 90 degree angle once you get one side flat with a planer. Would you then just keep rotating the stock until you’ve got parallel sides?
I’m a bit confused if this tool will serve both purposes in my shop.
10 replies so far
116900 posts in 3480 days
#1 posted 01-21-2010 08:16 AM
Some jointers do have a planner underneath so it’s a combination tool. I’m not familiar with the ridgid brands to be able to tell you for sure.
You start by jointing one face and one edge then you shave of the other side with your planner and use the edge that you jointed up against your fence on the table saw making all four side parallel,
View rweitz's profile
rweitz
116 posts in 2981 days
#2 posted 01-21-2010 08:37 AM
I don’t know much about the question, but there are some reviews right here on LumberJocks if you do google it you can ask thems that have the same machine!
-- You cannot build a reputation on what you are going to do. - Henry Ford
27251 posts in 3725 days
#3 posted 01-21-2010 12:59 PM
There is no difference between a jointer/planer and a jointer. Jet is the only manufacturer that I am aware of who offers combination machines. Craftsman jointers are usually labelled similar to this as well. To me it is a useless term that implies the tool can be used in both operations. But I would never attempt to try and thickness material on a jointer.
View PG_Zac's profile
PG_Zac
368 posts in 3291 days
#4 posted 01-21-2010 01:24 PM
I have a Felder Jointer/Planer, although the documentation refers to it as a Thicknesser/Planer.
As Jim said, this is a combination machine that has a Jointer on top, and a Planer below where the material is fed under the same cutter head on a second table. Only a genuine double function machine should be called a Jointer/Planer or a Thicknesser/Planer.
In European terminology, what you refer to as the Jointer is the planer, and what you refer to as the Planer is the thicknesser. So on the top table you plane the wood straight on one face and one edge (jointing), then you plane the wood true and parallel down to the desired thickness (planing) between the lower table and the cutter.
Ah the wonders of different versions of English.
View Dusty56's profile
Dusty56
11819 posts in 3591 days
#5 posted 01-21-2010 03:13 PM
In the USA , it is a jointer only. The dual term refers to …oh never mind …PG_Zac said it all : ) LOL
this is one of the JET models that actually do both processes.
http://lumberjocks.com/reviews/1180
View SnowyRiver's profile
SnowyRiver
51457 posts in 3383 days
#6 posted 01-21-2010 04:08 PM
I find that sometimes its called both. A jointer basically is an edge planer. Also if you lay the board flat, providing it is narrower than the cutter head, it can be used as a planer.
-- Wayne - Plymouth MN
tolmeda
#7 posted 01-21-2010 08:35 PM
Thanks for the clarification, everyone.
View PurpLev's profile
PurpLev
8534 posts in 3551 days
#8 posted 01-21-2010 08:41 PM
jointer/planer refers to the simple name of ‘jointer’ as it creates a flat PLANE – thus ‘planer’.
what the US is calling a planer is actually a shorted name for a thickness planer, or a thicknesser – which created a 2nd PLANE at a given THICKNESS.
jointer/planer = jointer
thickness planer = planer
combination planer/jointer = both a jointer AND a planer
TopamaxSurvivor
18189 posts in 3579 days
#9 posted 01-21-2010 09:14 PM
This sort of confuses me too:-( From looking at the pics of the actual machines, most of that they call jointer/planer are only a jointer. I suppose they are calling planning one side up to the width of the cutter planning.
View JasonIndy's profile
JasonIndy
187 posts in 3338 days
#10 posted 01-21-2010 09:58 PM
I think in the UK what we call a jointer is called a planer and what we call a planer they call a thicknesser. I had to read through a whole bunch of scientific explanations that confused me until I actually watched the two tools in use and then it made sense.
