What am I doing wrong?
« back to Joinery forum
Forum topic by KMX posted 01-03-2016 04:58 PM 1269 views 0 times favorited 14 replies Add to Favorites Watch
View KMX's profile
KMX
4 posts in 901 days
01-03-2016 04:58 PM
Topic tags/keywords: question
Hello all,
I am trying to make perfect straight crosscuts for a face frame using a Dewalt DW713 10” miter saw with a 80T blade. However, this keep happening…
The images show a finished 1×2 just cut and then placed back side by side. The gap is the exact path the blade has traveled.
Tried:
Using a different power outlet.
Different “brand new” blade.
Loosening/tightening the blade bolt.
Using a sacrificial zero clearance fence.
Many thanks!
14 replies so far
View MadMark's profile
MadMark
979 posts in 1479 days
#1 posted 01-03-2016 05:37 PM
Your miter guide is not exactly perpendicular to the blade. It also looks like the stock is slipping as you cut, perhaps a strip of sand paper on the face of the miter fence will help. A ZCI may also help the edge shredding. Saw slower.
When all else fails hit it with a hammer!
M
117120 posts in 3603 days
#2 posted 01-03-2016 05:46 PM
What mark sad or you blade is bent or your bearings are bad in the chop saw, turn it on and see if you blade wobbles from side to side a little when looking straight at the edge of the blade. If so you need a new blade or a saw shop might be able to straighten it.
View Holbs's profile
Holbs
1878 posts in 2055 days
#3 posted 01-03-2016 05:51 PM
have you fine tuned your saw? My Bosch miter saw was not perfectly aligned out of the box. I had to spend 2-3 hours with a square to make fence, blade, compound angles, etc exact.
See if this helps at all: https://www.youtube.com/watch?v=OuaoxMWQZkQ
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View MrUnix's profile
MrUnix
6766 posts in 2225 days
#4 posted 01-03-2016 06:49 PM
Adjust your saw according to the manual. It has the procedure for squaring the blade to the table and the fence to the blade – starting on page 6.
View KMX's profile
KMX
4 posts in 901 days
#5 posted 01-06-2016 04:53 AM
Thank you very much for the replies.
Recalibrating the saw unfortunately did not yield any positive results, nor did clamping the stock to be cut in place. I eventually opted for a new lower tooth blade and that seems to have done the trick. How my original blade became warped I am no sure, but I’m guessing I over tightened the blade bolt a couple times.
Thank you for the input.
View Shadowrider's profile
Shadowrider
183 posts in 1235 days
#6 posted 01-06-2016 05:03 AM
If you are using a thin kerf blade (common on mitre saws and blades sold for them) it may be flexing. A stiffener might help.
View TTF's profile
TTF
154 posts in 3204 days
#7 posted 01-06-2016 05:05 AM
I think something is loose and you’re getting side-to-side drift.
-- Troy | http://tf-workshop.com | The more I see nature, the more I am amazed at the Creator. - Louis Pasteur
View KMX's profile
KMX
4 posts in 901 days
#8 posted 01-06-2016 06:20 AM
I did forget to mention that the uneven crosscutting was an issue on my old Hitachi miter saw, hence I am suspecting the blade as the culprit since the same problem is happening on the brand new Dewalt DW713.
@Shadowrider
The idea of a stiffer blade is very intriguing. I am indeed using a thin kerf blade (very common). Do you have any recommendations for a thicker blade?
Many thanks.
View TheFridge's profile
TheFridge
9608 posts in 1512 days
#9 posted 01-06-2016 06:39 AM
I’d say just don’t tighten it with the hand of God and you should be fine. Stiffeners could limit depth of cut.
View EEngineer's profile
EEngineer
1103 posts in 3639 days
#10 posted 01-06-2016 11:22 AM
I saw similar things when I tuned up my HF 12” slider. I spent a long time “tuning”, got everything aligned perfectly BUT I still saw crap like you show in your pictures.
Eventually I scrapped the blade that came with the saw and put on a Diablo 80 tooth blade. Cleared that right up! Interestingly enough, the original blade was full kerf and the new Diablo was thin kerf – no stiffener. I can’t recommend the Diablo series of blades enough. They have migrated to all my circular tools in the shop – table saw, circular saw and miter saw.
I think the cheaper blades actually flex during the cut. If I look closely at your first picture, it seems like it isn’t a straight cut – the cut looks bowed in the center. That’s what I experienced on my saw. I am beginning to believe that the blade makes a huge difference!
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1248 posts in 1739 days
#11 posted 01-06-2016 11:48 AM
One last question that has not been asked: Were the cuts shown done using the “sliding” function on the saw?
I have found that even on brand new saws they can have quite a slack and is, in that case, best used ony for rougher cuts. Lock the saw and use only plunge cuts for critical stuff.
Hope this help!
-- "Do or Do not. There is no try." - Yoda
View Kazooman's profile
Kazooman
1030 posts in 1978 days
#12 posted 01-06-2016 01:09 PM
Hope this help!
- kaerlighedsbamsen
It is a compound miter saw, but I don’t believe it is a slider.
View KMX's profile
KMX
4 posts in 901 days
#13 posted 01-06-2016 04:22 PM
The DW713 is indeed a non-sliding miter saw.
I will try a thicker blade and see if that makes an improvement.
View waho6o9's profile
waho6o9
8207 posts in 2603 days
#14 posted 01-06-2016 04:29 PM
That happened to me so I used a magnetic angle cube and found out
I had a bent blade. Oops.
Put on new blade and the cube read zero in different locations.
Good luck now
