Loud squeel while scrolling? Normal?
« back to Scrollsawing forum
Forum topic by RustyHacksaw posted 01-03-2016 05:31 AM 1411 views 0 times favorited 8 replies Add to Favorites Watch
View RustyHacksaw's profile
RustyHacksaw
144 posts in 1460 days
01-03-2016 05:31 AM
Have never used a scroll saw before. Bought an old craftsman 16” single speed. Put a Ryobi blade in it from Home depot.
Turn the saw on and it is smooth, and very quiet. No vibration, and it just hums.
Starting to cut, it is very loud. Shrill noise. Definitely to the point of needing hearing protection.
Having never used one before, is this normal? If so, do you wear hearing protection when you all scroll? If it is not normal, what is causing it? How can I fix it to make it quieter? Thoughts?
Thanks.
8 replies so far
View MrUnix's profile
MrUnix
7037 posts in 2396 days
#1 posted 01-03-2016 05:48 AM
No, not normal… but without seeing/hearing it or knowing anything else – you are about the only one who can determine where it’s coming from.
View TheFridge's profile
TheFridge
10691 posts in 1683 days
#2 posted 01-03-2016 05:52 AM
Check the belt maybe?
View dhazelton's profile
dhazelton
2790 posts in 2493 days
#3 posted 01-03-2016 02:46 PM
If it’s the blade and not the belt or a bearing then you aren’t matching the blade type to the wood. Wood may be too thick or very hard or your cut radius is too tight. Exactly where is the noise coming from?
RustyHacksaw
#4 posted 01-03-2016 03:15 PM
It is coming from the actual cut. There is no noise until I start cutting. I tried to wax the blade, didn’t help.
View Jim Finn's profile
Jim Finn
2686 posts in 3119 days
#5 posted 01-03-2016 03:39 PM
What you describe is not normal at all. What wood are you cutting? Because you are new to using a scroll saw I want to mention, Blade should be so tight that when plucked it gives a high pitched “ping” . Feed the wood very slowly. Do not push very hard at all. A scroll saw is absolutely the slowest cutting power tool. If you push the wood to the side it may be touching the side of the opening in the table. I would also try a new blade. One mistake we all make occasionally is to put the blade in up-side-down or even backwards. Any blade you get from a big box store has two characteristics. Very expensive and poor quality. DO a search for blades on line. Brands I have used are. Olsen, Flying Dutchman. About twenty cents a blade. Places to buy them are “Wooden teddy bear” and “Sloans” If you call them and tell them what you are cutting they will recommend a good blade to use.http://www.sloanswoodshop.com/
-- No PHD just a DD214 Website> craftingcouple.com
RustyHacksaw
#6 posted 01-03-2016 03:59 PM
Is there any concern that the speed is too high? Being that it is not adjustable speed?
You feel the cheap (or rather, very expensive) Ryobi blades from HD are the culprit? I have tried to cut 1/4” Cherry, 1/2” plywood, 3/4” pine. All sound the same.
View bearkatwood's profile
bearkatwood
1663 posts in 1208 days
#7 posted 01-03-2016 04:04 PM
If it is only when you are cutting I would think it has to be something with the arbor movement. It could also be that the material you are cutting is the issue, then I would say try waxing the blade and see what happens?? Good puzzle. Sorry can’t be of more help. Spray that whole think down with lubricant is what I would do, maybe soak it in an oil bath ;)
-- Brian Noel
View Fettler's profile
Fettler
200 posts in 2194 days
#8 posted 01-03-2016 05:02 PM
Vibration. That’s what causes sound.
Either the saw itself is Bent or the blade is just crap. Cheapest diagnostic step? Buy a new blade. I suggest and aggressive toothed Olson blade:
https://www.amazon.com/Olson-Scroll-Blades-Thick-Wood/dp/B015091I60/ref=cm_sw_em_r_awdtod_XnvIwb0W1CWJ2_tt
I’ve had good luck with these. IIRC craftsmanship use pin end blades. You can also get them from woodcraft (or woodcraft full filed through Amazon).
Or maybe buy a multipack.
-- --Rob, Seattle, WA
