Small workshop ideas
Forum topic by Bama70 posted 01-03-2016 02:31 AM 1104 views 0 times favorited 6 replies Add to Favorites Watch
View Bama70's profile
Bama70
24 posts in 1285 days
01-03-2016 02:31 AM
I’ve been using half of our 24×30 garage as workshop. But I have a 10×20 out building that I’m thinking about setting my workshop up in it. Does anyone have a similar size workshop or any ideas for setting up a shop that size?
-- Stephen, Oxford, Alabama
View Jim Finn's profile
Jim Finn
2648 posts in 2891 days
#1 posted 01-03-2016 02:55 AM
I once had a shop that shape and size and I installed wall mounted benches along three walls and set my equipment on it. When I up graded to floor mounted equipment like a band saw, I just cut part of the wall mounted bench away to accommodate it. I made the bench tops of MDF.
-- Website is https://craftingcouple.com/
View conifur's profile
conifur
955 posts in 1121 days
#2 posted 01-03-2016 03:07 AM
Get some heavy craft paper in white, a drafting scale ruler, cut the paper to your shop size, 1”’ = 1 ‘and draw a grid on it, of 1”’ then get some contrasting construction paper and do the same scale for its shape of your machinery and benches, move the shop machinery, work bench around on the floor grid to see what you like and works for you.
conifur
#3 posted 01-03-2016 03:11 AM
PS also if you any doors that swing in to the shop to add the door swing/arc on the floor plan.
View sawdustdad's profile
sawdustdad
354 posts in 854 days
#4 posted 01-03-2016 03:17 AM
It depends on what you are building and what tools you have. That would be plenty big for a turner making bowls, pens, etc. Or someone making bandsaw boxes or small woodworking projects. It would be large enough for a furniture or chair maker using mostly hand tools. It would be too small for a cabinet maker, making kitchen cabinets using 4×8 sheet goods.
As long as your projects and tools fit the space, you’ll be fine. Keep the tools on mobile bases so you can move them around as needed. Heat, A/C, good lighting, stable floor are all important to being comfortable.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View benchbuilder's profile
benchbuilder
284 posts in 2420 days
#5 posted 01-03-2016 12:21 PM
I once had a 11×20 shop and built three canoes, tables and 8 rocking horse in it. Your only limited by your thinking. There is usually a way to do most anything if you try!!!
View rwe2156's profile
rwe2156
2886 posts in 1450 days
#6 posted 01-03-2016 02:30 PM
My very first “shop” was an 8X12 storage building. Impossible to work in.
The next was 12X16. Not impossible but pretty difficult.
I think 11×20 will be very hard to work in unless you don’t use power machines.
My suggestion is to add onto the building if you can make it 20X20 at least.
