Beginner Carving tools
Forum topic by NikBrown posted 01-20-2010 10:42 PM 2145 views 0 times favorited 1 reply Add to Favorites Watch
View NikBrown's profile
NikBrown
49 posts in 3104 days
01-20-2010 10:42 PM
So I want to try my hand at carving. I’m going to do a crushed turquoise stone inlay in my wife’s initials on top of a box (or something).
Here is about what I want to carve I’m thinking somewhere around 2”x2”:
Then fill with crushed stone.
What 2-3 basic carving tools would I need? I’m probably going to be carving this into wenge or walnut so they can’t be too flimsy.
I was looking at these (a bit more than I was planing on spending… but if I can get away with only getting 2…)
Ashley Iles - Individual Block Cutters - Chisels
What’s a decent beginner set to play with and carve into hardwood. Because I’m doing stone inlay I basically just need to cut the outline and then remove the wood to a depth of 1/8” or so I’m guessing. Any tips?
I really have no idea what I need… something to cut an outline and something to remove the center?
-- http://digitalwoodworker.com/ - Where woodworking and technology somehow get along.
1 reply so far
View reggiek's profile
reggiek
2240 posts in 3268 days
#1 posted 01-20-2010 11:22 PM
Being a newb carver myself…I found a great website and source of carving information. It is from a Ma & Pa pair in Washington State…and they are highly regarded in all the carving blogs and web groups that I have researched and joined. The Company name is Little Shavers and here is a link. I would only recommend carving if you want to go further then inlay work.
Now….if you are just going to inlay initials – or pretty much plan on inlaying rather then carving….why don’t you use a router?? You can use an inlay template (built for inlay work)...even make your own without having to buy additional tools or taking the time to hand carve? I would certainly research that method before resorting to hand carving. Also, you might want to look into rotary tools to do the inlay work…there are great router bases for them to allow you to be very precise in making the inlay slots….they are fairly inexpensive and have the extra convenience of being useable for a lot of other things.
Just my .02 cents.
