There a better value than the Ridgid DP1550 Drill Press?
Forum topic by Fallon posted 01-20-2010 10:10 PM 2567 views 0 times favorited 7 replies Add to Favorites Watch
View Fallon's profile
Fallon
90 posts in 3093 days
01-20-2010 10:10 PM
Topic tags/keywords: question drill press
I’ve read all of the generally pretty good reviews on the DP1550 and like the look of them when browsing in HD. Is there any similar sized drill press in a similar price range that I should be looking at?
Still cruising Craigslist and may end up going the used route instead of new. A couple have caught my eye including a half priced used DP1550.
Devin
7 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3613 days
#1 posted 01-20-2010 10:15 PM
not sure how much its going for but I got my 16.5” Delta on CL for real cheap. if you’re patient, there are some great offers to be had there. a DP is one of the more simple machines, and most of them offer very similar features.
View dbhost's profile
dbhost
5705 posts in 3197 days
#2 posted 01-20-2010 10:29 PM
I have a Northern Tool 16 speed, which is sold under a different label as the Central Machinery 43378 and runs for $189.00.
The quill travel on the DP1550 is a full 3-3/4 making it a one pass affair to through drill 4x stock. However you lose 4 speed settings, which, depending on how big or small of bits you use, might be important to you. I know I have some big forstners, and small Titanium bits etc… that obviously cannot be run at the same speed…
I got my DP used (Craigslist) for $75.00. Now the DP1550 sells new for $299.00, if you found an excellent condition DP1550 for $150.00, I would say RUN don’t walk to go get the thing…
Fallon
#3 posted 01-20-2010 11:32 PM
http://denver.craigslist.org/tls/1552424650.html
unknown condition & a 2 hour drive each way. May get motivate to go take a look at it with my dial indicator, or may just keep an eye on my RSS feed for “drillpress | drill press” in the couple of nearby Craigslist cities.
The DP1550 will do 300-3100, what does the Norther Tool do? I’d assume the lost speeds would be in the middle range somewhere not necessarily at the top & bottom end with the fewer gears/pulleys.
View Sawdust4Blood's profile
Sawdust4Blood
403 posts in 2987 days
#4 posted 02-16-2010 01:40 PM
I bought a DP1550 because I happened to chance on my local HD clearing some out for $149. After the military discount, I was out the door for $135. I couldn’t be happier with it. Obviously it’s not the top of the line but also not anywhere close to a top of the line price. All adjustments were true straight from the box and set up was easy. The light uses an appliance size bulb (though the instructions fail to mention the size required). There is a little more play in the table height adjustment than I would like and the column lock handle is too short/close to the column but all in all well worth the money.
-- Greg, Severn MD
Fallon
#5 posted 02-16-2010 05:24 PM
I ended up finding a nice Craigslist special SteelCity 17”. Some guy who allegedly only used it 6 times sold it for $200. Had a good covering of dust, but more or less looked new.
View falegniam's profile
falegniam
335 posts in 2918 days
#6 posted 11-26-2011 07:11 AM
I was lucky enough to find a brand new DP1550 last week for $300. I scooped it right up :) What did you end up getting?
-- If you work you eat - If you don't work, you eat, drink, and sleep.
View Moron's profile
Moron
5032 posts in 3858 days
#7 posted 11-26-2011 07:30 AM
buy used
Ridgid is nothing more then the corporate greed that preys on the unsuspecting fool
but in a “pinch” ………….its a cheap solution to a big problem
