Cutech planers
Forum topic by leftcoaster posted 01-02-2016 10:39 PM 1980 views 0 times favorited 2 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
203 posts in 786 days
01-02-2016 10:39 PM
Topic tags/keywords: planer cutech
I’m thinking seriously of purchasing a planer from Cutech. They have several models and no easy-to-understand feature comparison chart.
Has anyone here done the due diligence to work out what you gain with each step up in price? I know they have more depth stops and bigger posts. I’m just not qualified to determine how much I’d need/value these things as a hobbyist who has never touched a planer before.
2 replies so far
View pintodeluxe's profile
pintodeluxe
5569 posts in 2723 days
#1 posted 01-03-2016 03:46 AM
The H on the model # indicates helical head. However the Cutech and Steel City planers are not truly spiral or helical heads. They are correctly classified as segmented cutterheads (often Accuhead style). They take 2-sided HSS inserts, compared to the 4-sided carbide inserts on Shelix heads.
Carbide inserts are available for those machines, which last a lot longer than HSS. Fine Woodworking did a review of the Accuhead style machines and they cut well, but tearout was no better than straight knives.
I mill a lot of figured oak so I use a Shelix head which is superb.
View Spunk4ya's profile
Spunk4ya
14 posts in 1216 days
#2 posted 05-18-2016 05:41 AM
I have a accuhead for my Ridgid planer, swapped it for the 13” triple setup. Its not as smooth however running carbide cutters now for about 6 months, I’m really happy with the cut. The shinmax accuhea isn’t a true helical, more so it’s a segmented head (craftsman, Rikon, steelcity, cutech and General all use the same 2 cutter head)
I have found that I sand more to get the ridges out but the biggest benefit imo is if you knick a blade, you just spin the one damaged head around and you’re good as new. 26 cutters, 2 sides each sure seems more forgiving than a 3 knife, 2 side blade set…and the inserts are less than 2.50 each!
I’d love to hear how you guys decided but also what luck you have. Q
-- CustomsByQ
