Show me your scrap lumber storage cart
Forum topic by Joel_B posted 01-01-2016 04:45 PM 3137 views 2 times favorited 16 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
342 posts in 1380 days
01-01-2016 04:45 PM
Looking to build something like this to store scrap lumber that I should throw away but can’t.
Must have wheels and be space efficient. The other day my wife slipped and fell on some pieces I had lying on the floor and I am really pissed at myself about it.
Also looking to build some wall racks, it seems metal pipe for the shelf is popular:
-- Joel, Encinitas, CA
16 replies so far
View BurlyBob's profile
BurlyBob
5494 posts in 2264 days
#1 posted 01-01-2016 04:51 PM
That top one is a dandy. Don’t have room for the bottom one.
View Sarit's profile
Sarit
549 posts in 3139 days
#2 posted 01-01-2016 08:19 PM
I was gonna build a lumber rack until I found that lowe’s has them on sale now for $20 each.
Portamate Wood Rack
You can even build a cart frame and attach the portamate to it. I like it because the steel construction allows you to store a little more in the same space and at $20 a pop, the price diff between it and DIY is pretty small.
View MadMark's profile
MadMark
979 posts in 1452 days
#3 posted 01-01-2016 09:23 PM
My ‘scrap storage’ is the concrete floor to the left of the saw!
Spending good $ on scrap storage is a little redundant. The scraps only have value if they’re free. The more cost to store them the less the savings from having them. Eventually the law of diminishing returns kicks in and it reverts to being OCD.
I milled some moulding for an in process job I keep in a 4” cardboard tube. I use the shelf in the OSS stand for shorts from 12” to 18”
I don’t inventory much lumber so storage isn’t an issue. I use down to tiny pieces & those get fed to the model maker for miniature lumber.
Its hard to store much in an 8×10 shop:
(Note lumber storage leaning on planer. ..)
Joel_B
#4 posted 01-01-2016 10:47 PM
I was gonna build a lumber rack until I found that lowe s has them on sale now for $20 each.
Portamate Wood Rack
- Sarit
Thats perfect, on my to pick one up.
View Kazooman's profile
Kazooman
1006 posts in 1951 days
#5 posted 01-01-2016 11:16 PM
The problem with these racks is they bear no relation to the typical “scrap” lumber one accumulates in the shop. I have pieces ranging from 1 X 10 X 8’ to chunks of more exotic wood that are 2×2x8”. It come in all widths, thicknesses and lengths. My guess is that most of what people save at the end of a project is nothing like the nice dimensional lumber shown on the rolling rack.
The Lowes rack doesn’t look very good to me. Not enough support for the el goth of the pieces. They are going to sag and take on a bow. They are cheap enough that I would suggest buying two and using them to double up on the support.
View bearkatwood's profile
bearkatwood
1572 posts in 1011 days
#6 posted 01-01-2016 11:22 PM
I have a huge scrap wood storage cart, it has a door on it and a workbench inside. I am not very organized so the wood kind of acts like my insulation and fills all the voids that are not being used by other tools.
-- Brian Noel
View MrUnix's profile
MrUnix
6715 posts in 2198 days
#7 posted 01-01-2016 11:27 PM
- Sarit
Unless you happen to have a welder and some old bed frames :)
(which also lets you design it for your specific needs!)
woodbutcherbynight
4555 posts in 2408 days
#8 posted 01-02-2016 04:33 AM
- bearkatwood
ROFLMAO
View OSU55's profile
OSU55
1672 posts in 1988 days
#9 posted 01-02-2016 06:37 AM
If it was scrap you wouldn’t save it – scrap goes in the trash or gets burned. If you keep it, it’s leftover, salvage, remnants, etc., but it ain’t scrap.
View bondogaposis's profile
bondogaposis
4727 posts in 2350 days
#10 posted 01-02-2016 03:13 PM
Here is a cart I built for smaller pieces.
This a lumber rack for longer pieces, and by laying a piece of plywood across a couple of spans you can also use it to stack smaller pieces as well.
-- Bondo Gaposis
View ChefHDAN's profile
ChefHDAN
1062 posts in 2849 days
#11 posted 01-02-2016 03:42 PM
I’ve got most of what is already shown, but also added this one for all the smaller bits and pieces that I had been accumulating in buckets and then never looking at. This is somewhat styled similar to racks I use in kitchens where it’s more efficient to store in the vertical. There’s also a good storage thread here
Joel_B
#12 posted 01-04-2016 02:21 AM
Portamate Wood Rack
- Sarit
- Joel_B
Started to install the Portamate rack and the sheet metal screws that hold the horizontal bars in place strip out the holes in the vertical bar, I don’t really trust that to hold. I drilled out the hole all the way through so I can install #8 machine screws and put a nut on the back. Too bad they didn’t do that way. Of course I don’t have the right size screws in my infinite screw collection. Also the 110 lb rating per rack is no joke, I pushed down on a bar and its not that sturdy but it will do. Still for $20 not bad.
View GregTP's profile
GregTP
62 posts in 942 days
#13 posted 01-04-2016 12:46 PM
At first I built this as a single unit that took up a whole wall, then got smarter and cut it in half to use up the upper wall space. I have 11ft ceilings in the shop which is a big help.
The whole thing cost $30 and only took a few hours to make and install. 2×4s with a 1” hole drilled at a 5 degree angle, then 2ft sections of 1” black iron pipe.
I am also thinking of building a cart for small stuff, as you can see, I end up stacking alot of small bits on top of the larger ones which becomes a real pain when you need to get to something at the bottom.
-- From exercise machine warning label: "Step ladders can cause injury and even death; the ROM machine is more dangerous than a stepladder"
View Underdog's profile
Underdog
1095 posts in 2035 days
#14 posted 01-04-2016 01:02 PM
Ummmm….
My whole shop?
-- "woodworker with an asterisk"
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1576 days
#15 posted 01-04-2016 01:45 PM
I have a couple of the portamate racks, pretty good I think, for $20 I’ll prob get another to add some more support to the two I got. The screws that go under the support arms don’t tighten down, but I don’t see them falling out. The one negative this is the clearance isn’t a lot so stickering boards can be done but you won’t have much wood on there. Of course if you sticker on there, shouldn’t have to worry about going over weight, I have mine loaded down.
