Remote dust collector switches
Forum topic by john200 posted 01-19-2010 07:17 PM 5199 views 1 time favorited 11 replies Add to Favorites Watch
View john200's profile
john200
25 posts in 3047 days
01-19-2010 07:17 PM
I would like to add a remote switch to my dust collector. I have a 1 1/2 hp system and was hoping somebody out there would have a suggestion as to which switch they might recommend?
Thanks,
John200
-- John200, Vancouver, WA
11 replies so far
View northwoodsman's profile
northwoodsman
242 posts in 3744 days
#1 posted 01-19-2010 07:37 PM
I have one that I picked up at Woodcraft. It’s been in use for 3+ years now and has never failed. I couldn’t imagine getting by without it.
-- NorthWoodsMan
View russv's profile
russv
262 posts in 3167 days
#2 posted 01-19-2010 07:46 PM
i have one for about 7 years now. get extra remotes. the best thing i ever did.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
View Abbott's profile
Abbott
2570 posts in 3301 days
#3 posted 01-19-2010 07:57 PM
I purchased mine from Amazon dot com for $40.94. It is a Shop Fox d3038 110 volt 20 amp dust collector switch. The first one they sent me didn’t work and I returned it for a replacement. It took about a month from the first order until I had the switch installed and working. Even with the hassle it was forty bucks well spent and the convenience is well worth it.
It seems Amazon does not carry the switch at this time, I found one here at this sight for $37.69.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View ShannonRogers's profile
ShannonRogers
540 posts in 3786 days
#4 posted 01-19-2010 08:05 PM
I have used this one bought at Woodcraft for several years. I moved to a 1.5 HP DC about a year ago and it was working fine until it suddenly started tripping the DC breaker on every startup
-- The Hand Tool School is Open for Business! Check out my blog and podcast "The Renaissance Woodworker" at www.renaissancewoodworker.com
3809 posts in 4019 days
#5 posted 01-19-2010 09:22 PM
I really hate advertizing sumantics but it sounds like they are saying ” up to but not including 1.5 hp”.
Sometime you have to wonder?
p.s. I have that switch designed for 220 volts and so far not problems at that voltage.
I agree with Russv- get extra remotes.
Rick Dennington
5859 posts in 3192 days
#6 posted 01-19-2010 09:50 PM
Greetings john200:
I’ve used the Lone Ranger Remote Control for about 12 years, and it’s a good one. Not one problem. And…..........I’m still using the same 9 volt battery that came with it, if you can believe it. I keep expecting it to go anytime, but not yet. It’ll reach about 75 yards, and anywhere your in the shop, it will turn on….. even behind a wall…... Check them out….....they’re red.
TopamaxSurvivor
18270 posts in 3674 days
#7 posted 01-20-2010 12:17 AM
BE sure to get it rated for your HP or above. These modern HP ratings for contacts are very marginal in my experiences :-((
View papadan's profile
papadan
3584 posts in 3366 days
#8 posted 01-20-2010 01:02 AM
I will second the Long Ranger remotes. Both of mine are 8 1/2 years old now and still working perfect. I use a 220 on my Grizzly 2hp DC system and I have a 110 that i use on an exhaust fan.
View Sawkerf's profile
Sawkerf
1730 posts in 3066 days
#9 posted 01-20-2010 02:19 AM
I used the 110v Shop Fox remote for 3-4 years and just got the 220v version last month after I switched my TS and DC to 220v.
One of my 110v remote switches died (I just wore it out) several months before the changeover, and it’s good to have two remotes again. I keep one at the TS and the other at my SCMS station and am never more than a couple of steps from one of them.
Todd A. Clippinger
8901 posts in 4097 days
#10 posted 01-20-2010 02:24 AM
I have both of the ones shown above by Abbott and ShannonRogers and they both work well and do not interfere with each other.
No problems with either.
View Taigert's profile
Taigert
593 posts in 3838 days
#11 posted 01-20-2010 08:15 AM
I have the big Shop Fox 5 hp cyclone, wired to 220 volts on a 30 amp breaker. I don’t know what I would do with out the remote. It sure saves me a lot walking back and forth.
Like others have said get extra fobs, they are real easy to set down some where. I always wear Carhart bibs and have gotten into the habit of putting the fob in my bib pocket all the time.
[IMG]http://i884.photobucket.com/albums/ac41/Taigert/Shop%20Fox/IM000511.jpg[/IMG]
[IMG]http://i884.photobucket.com/albums/ac41/Taigert/Shop%20Fox/IM000510.jpg[/IMG]
-- Taigert - Milan, IN
