Pen finish problem
Forum topic by bayspt posted 01-19-2010 06:36 AM 1500 views 0 times favorited 11 replies Add to Favorites Watch
View bayspt's profile
bayspt
292 posts in 3704 days
01-19-2010 06:36 AM
Topic tags/keywords: pen turning finshing problem
So I started down the slope of pen turning. I’ve done about 15 so far. I have been using the CA glue and BLO finish with some good success as of late. The problem I am having is that on darker woods especially, I get shiny spots that appear to be under the finish. I sand 220 320 400 1000 then apply BLO. 1000 again then wipe with acetone. When the acetone has evaped, I micro mesh from 1500 to 12000. Then I apply the finish. I apply 4-6 coats at about 900 rpm. Using thick CA I put a puddle on a paper towel and apply then put one drop of BLO on the same spot and work it back and forth till I feel the CA is cured. I then sand 1000 again and wipe with Denatured Alcohol. I then apply 2-4 coats starting at 900 rpm when the glue goes on (using a smaller amount) and when I go to BLO I up the speed to about 2300 rpm. I then micro mesh from 1500 to 12000 again. I take the mandrel off the lathe and go to the stiff flanel buffing wheel with rouge. Then to the soft flanel buffing wheel with white diamond rouge. I get a nice deep luster and high shine that seems to last well with handleing, but sometimes I get the shiney spots. It almost looks as if there is BLO trapped between layers, but I don’t know how. I would post some pics but I don’t know if a camera could even pic up what I am talking about. Has anyone else ran into this problem. Do you have a cure?
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
11 replies so far
View bill1352's profile
bill1352
130 posts in 3121 days
#1 posted 01-19-2010 01:54 PM
the video i saw had it the other way around without the acetone wipe. you put blo on, rub it in and then put the ca on the same spot on the paper towel. the next coat you put a drop of blo on a clean spot on the towel and a puddle of ca on that spot then put it on the pen with no sanding in between coats unless it isnt smooth. it only shows sanding to 600 grit but i like to go with the micro mesh too before the blo & ca. it brings out the grain better. it was a youtube video. easy to find just search for ca pen finish.
-- Keep Your Stick On The Ice
View Sawdust2's profile
Sawdust2
1466 posts in 4087 days
#2 posted 01-19-2010 02:12 PM
I like CA/BLO particularly when using a porous wood but my preference, and every pen turner has his or her own preference, is the rub on finish from Craft Supply in Utah.
I’ve never used acetone between coats so I can’t help one way or the other on that, but I did find out that less is more. 1-2 drops as opposed to puddle. When I cut down on the amount of finish per application, either CA/BLO or rub finish, the lustre just stood out. I tend to apply the finish at a slower speed and buff at a high speed.
Also, I put CA and BLO on at the same time. Works for me.
View branch's profile
branch
1142 posts in 3154 days
#3 posted 01-19-2010 10:17 PM
hi i am not firmalur with the finish you are talking about but what i do now is less is better than more i think you are trying to build up to much polish on the pens try to do all your sanding before you pot on any finish after sanding get the shaving and hold it to the pen just like sandpaper keep it there with pressure it seams to work for me have been doing it for a long time a old wood turner showed me a long time ago but be careful not to burn the pens try it it works
View grub32's profile
grub32
215 posts in 3048 days
#4 posted 01-20-2010 11:17 PM
I am new to the forum but not penmaking…I make all my pens with CA finishes. I highly recommend buffing out with a rubbing polish like auto polishing cream. I use novus2 with greatest success but mylands car polish works good and I have even heard that some are using brasso. I don’t use BLO….I just go straight CA. I have done both and I get more consistent results with just this CA and use lots of coats…About 6. Using accelerator, it takes me about 5 mins start to finish, that includes the MM to 12000. I dont use acetone to clean the blanks, I use DNA. That works best on all woods even oily.
If you have any questions, PM me and I can send some photos if necessary.
Grub
-- Educator by Day, Wood Butcher by Night!!
View Padre's profile
Padre
930 posts in 3489 days
#5 posted 01-21-2010 12:33 AM
I don’t use the acetone either. Are you using wood or polyresin blanks?
Also, the paper towel will make the ca cure faster than using a very small cloth.
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
Padre
#6 posted 01-21-2010 03:21 AM
I also found this. It is a good tutorial!
grub32
#7 posted 01-21-2010 04:35 AM
I have loaded a photo of my CA finish on an Amboyna Burl and Thuya burl to my projects if you would like to look at them.
I am also adding a pic of my christmas pen that I made using polyester resin.
Grub
bayspt
#8 posted 01-21-2010 07:36 AM
Thanks for all the help guys. I will have to try some of these suggestions when I get home from Turkey. Grub, How are you using the accelerator? I am really happy with the gloss and depth of finish I am getting if I can get rid of the shiny spots. I think I might try straight CA first.
grub32
#9 posted 01-23-2010 03:27 PM
Finally, got a video on youtube about my finish…http://www.youtube.com/grub32. Let me know if you have any questions.
Grub
bayspt
#10 posted 01-23-2010 06:06 PM
Thanks Grub. I will check it out as soon as I am back in the states. youtube is blocked in Turkey. Lucky LJ is not.
Padre
#11 posted 01-23-2010 07:53 PM
Hey Grub, that video was way cool. Thank you very much for posting it!
