Problem Centering Hinge Screws
Forum topic by Jim Crockett (USN Retired) posted 01-19-2010 04:00 AM 5971 views 0 times favorited 26 replies Add to Favorites Watch
View Jim Crockett (USN Retired)'s profile
852 posts in 3762 days
01-19-2010 04:00 AM
I seem to be having a lot of problems lately centering the pilot holes for hinge screws for my boxes. The hinges are small (3/4” x 1”) and use #2 brass screws and even a small deviance from the actual center can throw the alignment of the box top off.
I don’t know whether my eyes are getting old like the rest of my body or what, but…..
I cut nice, precise mortises for the hinges on the router table using Doug Stowe’s “flipping story stick” method. Then comes the problem of centering the holes for the screws. I use a very sharp awl but apparently not very well! For larger screws, I use the self-centering bits (bix bits) but they don’t make one for #2 screws.
Am I the only one who has this problem? Do any of you have any suggestions? It’s quite frustrating to repeatedly drill and fill these tiny little holes!!!
Thanks,
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
26 replies so far
View GMman's profile
GMman
3902 posts in 3726 days
#1 posted 01-19-2010 04:10 AM
Very small hinges tends to move on you try a little bit of double face tape to hold them in place so you can punch a hole for your screws.
View closetguy's profile
closetguy
744 posts in 3921 days
#2 posted 01-19-2010 04:31 AM
I use to have the same problem and finally broke down and bought a set of three bit centering bits from Rockler. It solved all my problems with centering the pilot hole.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View PurpLev's profile
PurpLev
8536 posts in 3677 days
#3 posted 01-19-2010 04:44 AM
I find that the self-centering bits when used slowly do a great job solving that problem.
#4 posted 01-19-2010 05:08 AM
The smallest vix bit that I have found is 5/64” which is just a bit large for a #2 screw. Too bad!
Jim
View FirehouseWoodworking's profile
708 posts in 3302 days
#5 posted 01-19-2010 06:28 AM
My first choice is a vix bit. If the bit is too large, then I’ll switch to a spring-loaded self-centering punch. Just a small tap of the hammer will mark the center. Then a drill bit of appropriate size.
As you’ve probably already discovered, the darker grain markings (I can never remember if they are the summer or winter growth rings) tend to be harder than the adjoining light (and softer) wood. The center punch is usually enough to keep the drill bit from wandering.
Good luck.
-- Dave; Lansing, Kansas
View Gene Howe's profile
Gene Howe
10548 posts in 3457 days
#6 posted 01-19-2010 01:26 PM
+1 on Dave’s method.
View Russel's profile
Russel
2199 posts in 3968 days
#7 posted 01-19-2010 01:44 PM
I hate hinges. The very problem you’re having is why very few of my boxes have hinges anymore. The little ones are really difficult to drill accurately and it’s complicated by the multiple prescriptions in my glasses.
View dusty2's profile
dusty2
323 posts in 3458 days
#8 posted 01-19-2010 03:20 PM
I don’t often do projects that use hardware as small as what you are using…but…I developed a little trick that works well for what I do build. I secure the hinges in the pre-cut hinge mortise using a touch of hot melt. I then center punch and drill the holes for the screws..and then.. install the screws.
If I don’t heavy hand it, the hot melt secures the hinge in the desired location until the screws are in place.
-- Making Sawdust Safely
View stefang's profile
stefang
15881 posts in 3363 days
#9 posted 01-19-2010 07:48 PM
I just gave up on metal hinges and now make my own wooden ones. I have never been able to install small hinges without a lot of problems. I know, my skills are lacking.
#10 posted 01-19-2010 09:26 PM
Has anyone ever tried an appropriately sized transfer punch to create a center dimple? Just wondering if it would be worthwhile investing in a set.
Jim
3809 posts in 4050 days
#11 posted 01-19-2010 09:41 PM
I find these gimlets helpful.
Sometimes power tools make it more difficult. <g>
This one is handy too.
http://www.leevalley.com/wood/page.aspx?c=2&p=32201&cat=1,43456
#12 posted 01-20-2010 12:05 AM
I had seen the Hinge Center Punch previously. I wrote to Lee Valley about it and they responded that it wouldn’t work in such a small hole. Drats!!! That would have been ideal.
Jim
#13 posted 01-20-2010 12:10 AM
You could make one Jim. It just a pin with a spring on it.
Try the workings from an old ball point pen.
View bigike's profile
bigike
4052 posts in 3317 days
#14 posted 01-20-2010 02:35 AM
that punch set might work i have one, i think? i also have the letter set too but i never used it the other puch set i use sometimes. What i do for hinges is eye it to the middle with a awl then i have a little hand drill that opperates by using your index finger and thumb to make it work and this is the best thing that works for me, sometimes. Ill try the punch set and let u know if u want?
View Dudley's profile
Dudley
742 posts in 3289 days
#15 posted 01-20-2010 02:58 AM
I use a pin drill as what bigike is describing. It will tighten on a 1/16” drill.
-- Dudley Young USN Retired. Sebastian, Fl.
