What to do with 3hp 1ph 220v motor
Forum topic by Padre posted 01-19-2010 12:42 AM 1402 views 0 times favorited 3 replies Add to Favorites Watch
View Padre's profile
Padre
930 posts in 3483 days
01-19-2010 12:42 AM
Topic tags/keywords: question compressor motor fix recycle repair
My compressor motor lost its key, and the pulley that was attached chewed up the shaft and keyway pretty good. The keyway is beyond filing and/or grinding. Other than that there is nothing wrong with the motor. Runs, is quiet, has maybe 10 hours on it max.
The motor new is over $400.00
BUT: I called our local electric motor repair facility and he said the shaft would have to be “re-metalized,” whatever that means.
He said it wouldn’t be cheap either. He didn’t elaborate on the price.
So here’s my dilemma: the compressor company already sent me a free new motor and the compressor is up and running. The old motor is pristine except for the shaft.
Should I just recycle it? Throw it away? Give it away? Have it re-metalized and then try to sell it?
What’s your advice?
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
3 replies so far
View bigike's profile
bigike
4052 posts in 3282 days
#1 posted 01-19-2010 12:55 AM
keep it till u decide what to do, also find out the price to re-metalize it just in case u want to sell later.
View fussy's profile
fussy
980 posts in 3045 days
#2 posted 01-19-2010 01:16 AM
Padre,
As you have nothing invested, try to build up the shaft with JB Weld. It’s a two part epoxy-like confection that after 24 hours can be machined like steel. Then, as Skeezics suggests, use a grade 5 or grade 8 set screw to secure it. You will always find a use for something right after the garbage truck leaves.
Steve
Padre
#3 posted 01-19-2010 01:44 AM
Good ideas!
