Cutting Board Glue Joint Problem - Fix or Firewood?
« back to Joinery forum
Forum topic by Keith Kelly posted 12-30-2015 02:50 AM 943 views 0 times favorited 3 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
263 posts in 1660 days
12-30-2015 02:50 AM
I’ve made a whole lot of cutting boards in the past year. This one is for a client, and I just noticed a spot where the glue joint is bad. I feel like I worked quickly and clamped well, so my guess is perhaps a wood shaving preventing the boards from making good contact.
If you were making this, what would you do? I’m considering building a new one for the client, but if there’s a legitimate fix, that would be good to know about.
The bad glue joint is between the Walnut and Maple, and goes about 3” in. Total cutting board size is 15×20.
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com
3 replies so far
View pwalter's profile
pwalter
79 posts in 2581 days
#1 posted 12-30-2015 03:12 AM
You can try using thin epoxy. let it run into the crack then reclamp it. Honestly, with it being for a client, and it being facegrain I’d probably just make a new one just to be safe.
View Betsy's profile
Betsy
3391 posts in 3892 days
#2 posted 12-30-2015 03:36 AM
I would rip it at the glue line and rip the other maple/walnut joint the same amount and re-glue. If you use a thin kerf blade and cut right down the middle of the joint – you won’t lose that much. Or you could make a new one for the client and just lop the bad end of the first one off and have a new, shorter board for yourself or as a gift or for another client.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View MadMark's profile
MadMark
979 posts in 1449 days
#3 posted 12-30-2015 05:24 AM
Rip just the walnut at the edge of the maple and make it 1/8” narrower, no-one will know if you don’t cut the maple
M
