Raised panels
« back to Joinery forum
Forum topic by Steve posted 12-30-2015 02:25 AM 921 views 0 times favorited 6 replies Add to Favorites Watch
View Steve's profile
Steve
186 posts in 1906 days
12-30-2015 02:25 AM
Used my shaper for the first time to make some raised panels for a small project I am building. This is the first time I have ever made them and they turned out not to bad. I used Royce//Ayr cutting heads and they cut very true and smooth. It was a little intimidating at first as that 2 lb. cutter turning at 8000 RPM. Could get quite nasty on the fingers. Anyway got through it and now have to figure out the powerfeed.
View sawdustdad's profile
sawdustdad
354 posts in 791 days
#1 posted 12-30-2015 03:48 AM
the doors look nice. I agree that the 5 inch dia. cutter is intimidating.
I built a sled with a pair of toggle clamps to hold the panels as I run them through the shaper. Keeps everything stable and keeps hands well away from the cutter head.
Did you cope and stick the stiles and rails? Looks like it.
I only use power feed for long strips like moldings or T&G work. Basically when I can’t use a sled.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2215 days
#2 posted 12-30-2015 07:40 AM
Doors looking good.
Try spinning two of these 9 inch cutters with a spacer between them. I don’t know off hand how much they weigh but it’s a lot.
That’s a 10 inch saw blade in the saw
View SirIrb's profile
SirIrb
1239 posts in 1136 days
#3 posted 12-30-2015 05:41 PM
When set up well you can raise the panels on 4 sides with the PF. I love them. Only thing to remember is to make sure the tires are getting a nice bite, the feeder is feeding at a bit of an angle towards the fence and I like to use a single board fence screwed to the fence and pulled into the running cutter so it is basically 0 clearance. In this way you can PF the panel 4 sides-end grade first-with no problem. I used this method in a production environment and made tons of RPs.
The ends of the cope and stick are tricky only in that you always want them held very firm. We used pneumatic clamps. 2 snaps up for pneumatic clamps. They basically = 2* airpressure. So I was clamping at 220 pounds.
I love shapers. Wish more people had and ran them.
Yes, heavy cutters are scary. I ran an insert head on a Yates N-4. It was all of 10 pounds easily. I never lost a knife but I did make a 1/2×3/4×16’ missile that came out of the PF and hit the shop wall. Bout pissed myself.
View AandCstyle's profile
AandCstyle
2978 posts in 2163 days
#4 posted 12-30-2015 11:50 PM
Geez, Steve, I don’t think they get much better than that. :)
-- Art
View dhazelton's profile
dhazelton
2689 posts in 2202 days
#5 posted 12-31-2015 02:15 PM
Those doors look great!
View jar944's profile
jar944
124 posts in 1343 days
#6 posted 01-01-2016 02:20 AM
Looks good.
Get the power feed up and working, it makes the shaper even better.
