Curious how long it would take a decent woodworker to build this?
Forum topic by mbaba posted 12-29-2015 12:12 AM 1303 views 0 times favorited 12 replies Add to Favorites Watch
View mbaba's profile
mbaba
3 posts in 846 days
12-29-2015 12:12 AM
I saw this little fixture added to a sectional divider in a store nearby and thought it looked great. How long do you think it would take a professional woodworker to put this together including staining?
TIA!
12 replies so far
View MadMark's profile
MadMark
979 posts in 1418 days
#1 posted 12-29-2015 12:25 AM
Depends on if it separate pieces, one piece scrolled, or just stamped ply.
To make just one or two is tedious and fussy, to set up a production line to run 100’s for furniture is something else entirely.
M
mbaba
3 posts in 846 days
#2 posted 12-29-2015 12:42 AM
I’d only be looking to do one. From the looks of it, it’s one piece.
mbaba
3 posts in 846 days
#3 posted 12-29-2015 12:42 AM
Assuming it’s one piece do you think it could be done in under 5 hours or is this much more time intensive?
MadMark
#4 posted 12-29-2015 01:23 AM
The only way to really know is to build a prototype.
Build it and see.
M
View gfadvm's profile
gfadvm
14940 posts in 2655 days
#5 posted 12-29-2015 01:54 AM
A pro would probably use a CNC machine to do that in a few minutes.
View David Taylor's profile
David Taylor
326 posts in 1053 days
#6 posted 12-29-2015 02:22 AM
I blew up your picture and it looks like it may have a mix of scrolling and carving to it. The scrolling could be done in an hour or so, the carving another couple, depending on the detail I can’t really make out
Overall, not including dry time for finish, I’d say under five hours is a safe estimate
-- Learn Relentlessly
View bearkatwood's profile
bearkatwood
1542 posts in 977 days
#7 posted 12-29-2015 02:27 AM
Depending on how intricate the carving would be, I would say probably an hour to and hour and a half. If there was call for multiples then it would probably be replicated on a cnc, but I would make the first by hand and use a probe to scan it so they all look hand made. The cost would be shop time plus the materials and any computer time needed, probably about $75-$150 depending on the shop and how intricate it needs to be.
-- Brian Noel
View rwe2156's profile
rwe2156
2881 posts in 1446 days
#8 posted 12-29-2015 11:48 AM
It all depends on how talented the carver is. Lots can go wrong with a carving like this so it would take an experienced carver to do it nicely.
I’ve seen similar cartouche-type carvings that a talented carver said took 2-3 hours start to finish.
I’ve seen a demo and once its scroll sawed out, it actually goes pretty fast (if nothing breaks).
For a novice like me, I’m guessing 4X that much time—and wouldn’t look nearly as good.
View Tennessee's profile
Tennessee
2860 posts in 2480 days
#9 posted 12-29-2015 01:22 PM
Although the one in your picture looks handmade, most major furniture companies I know of that would use things like this would either have it injection molded and spray/stained to look like wood, or the higher class companies would CNC it.
I’d think at least for a first timer, if successful many, many hours if carved, maybe a couple hours if you could scroll saw it out and use a Dremel to enhance the curls and round off the edges.
View JoeinGa's profile
JoeinGa
7735 posts in 1972 days
#10 posted 12-29-2015 01:54 PM
Maybe it’s just me, but I think it looks like plywood that’s been mostly cut with a bandsaw.
View Ger21's profile
Ger21
1074 posts in 3096 days
#11 posted 12-29-2015 05:03 PM
Um, that’s not how it works.
CNC can be a bit more complicated than most people think. First, you need an accurate CAD drawing or 3D model to start with, which may take anywhere from 30 minutes to a few hours, depending on what you have to go by.
Then you need to program the toolpaths.
Then figure out how to hold the part down while you cut all the way around it.
Cutting just one of something on a CNC may take just as long as doing it manually. It’s the second, third and fourth ones that get done a lot quicker.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View MT_Stringer's profile
MT_Stringer
3160 posts in 3196 days
#12 posted 12-29-2015 06:15 PM
Looks to me like just the cost of the wood could be expensive.
