Walnut and pore filler
Forum topic by horky posted 12-28-2015 01:17 PM 1238 views 0 times favorited 5 replies Add to Favorites Watch
View horky's profile
horky
249 posts in 3104 days
12-28-2015 01:17 PM
Topic tags/keywords: walnut pore filler grain filler
Walnut and Pore Filler
I am making a dining room table. Walnut as you may guess. Being in the open pore family of woods, I read that many use a pore filler to smooth it out and give the finish a smoother, richer, possibly glossier look. I have made walnut end tables, coffee tables, etc. and never used pore filler but am looking for some guidance/experience. Is it worth using? What brand? Application techniques? Any and all comments welcome. My finish will be a Danish Oil followed with some clear poly. Thanks for any and all help.
5 replies so far
View sawdustdad's profile
sawdustdad
366 posts in 1059 days
#1 posted 12-28-2015 02:25 PM
Nearly every factory built table top uses a pore filler, so it’s pretty typical to use. Most any commercial brand of filler will work, and application instructions are everywhere, so you can google it or look on youtube. The idea is to stain it dark, thin it to apply if needed, scrub it into the pores, and wipe perpendicular to the grain with a course cloth. Let dry and sand smooth. Apply finish, and then rub out with various abrasives to a fine polish.
If a mirror smooth surface is your objective, then a filler is probably the fastest way to get there, but be prepared for the polishing process.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View joek30296's profile
joek30296
53 posts in 3040 days
#2 posted 12-28-2015 02:27 PM
There are a number of YouTube videos on how to use paste wood filler. Also here is some pretty good info I got just “googling” how to use paste wood filler. Hope it helps. http://www.am-wood.com/finishes/filler.html
-- "There are two theories to arguing with a woman....neither of them work"
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1350 days
#3 posted 12-28-2015 02:51 PM
You definitely do not want to apply a finish over filler that is not completely dry. My rule is to wait at least three times the drying time listed on the can. I want the filler completely dry all the way down through the pore.
I don’t trust stain over a pore filler.
View mahdee's profile
mahdee
4006 posts in 1941 days
#4 posted 12-28-2015 05:56 PM
You always can fill the pores with poly.
-- earthartandfoods.com
View gfadvm's profile
gfadvm
14940 posts in 2864 days
#5 posted 12-29-2015 01:30 AM
The quickest and easiest pore filling technique is to use Timbermate black walnut color matched grain filler from Woodcraft, et al. An alternate method is to wet sand with BLO creating a slurry, wipe/squeegee across the grain, and resand after the BLO has cured. Both will work well but the Timbermate goes a LOT quicker and is pretty much foolproof. I use a credit card to apply and remove excess. It dries very quickly and sands easily.
