Band Saw Tension Problem!!
Forum topic by Woodworker101 posted 12-28-2015 09:58 AM 593 views 0 times favorited 3 replies Add to Favorites Watch
View Woodworker101's profile
Woodworker101
22 posts in 1744 days
12-28-2015 09:58 AM
Topic tags/keywords: question bandsaw blade
Hi LJ’s,
I recently bought a Laguna 14 twelve Band Saw for Christmas. I’m having trouble with releasing the tension using both the quick-release tension blade lever and the blade tension handle. You see, when I tension the blade using the quick-release tension lever, it tensions the blade nice and tight which isn’t a problem. The problem is when I deactivate the quick-release blade tension lever to change the blade, the upper wheel stays in the same position without lowering still applying tension to the blade. It is only until i rotate the blade tension handle a few times that I’m able to then push down on the wheel to release the tension and remove the blade from the machine. I know that pushing down on the upper wheel to get the blade off isn’t good for the machine, so that’s why i have stopped using it until i can resolve this issue.
Can somebody pleeeease help me with this???
Best Regards,
Jackson
-- Jackson, Australia,http://www.jacksonsfinecarpentry.com.au/
3 replies so far
View rwe2156's profile
rwe2156
2749 posts in 1353 days
#1 posted 12-28-2015 12:12 PM
Sounds like something is hanging.
Why don’t you call Laguna Tech Support?
View jacquesr's profile
jacquesr
339 posts in 1295 days
#2 posted 12-28-2015 03:18 PM
Can’t help much. When I release the lever, the wheel goes down.
Laguna support can help. Always been helpful. Good luck.
View WhyMe's profile
WhyMe
934 posts in 1433 days
#3 posted 12-28-2015 06:24 PM
Take the blade off and operate the quick release up and down and watch what’s going on to figure what’s hanging.
