Epoxy still tacky after 4 days
Forum topic by Robert212 posted 12-28-2015 01:17 AM 990 views 0 times favorited 12 replies Add to Favorites Watch
View Robert212's profile
Robert212
2 posts in 883 days
12-28-2015 01:17 AM
Does anybody know a fix for epoxy that has not fully cured? It is just slightly tacky. Thanks for you input.
12 replies so far
View MrUnix's profile
MrUnix
6706 posts in 2196 days
#1 posted 12-28-2015 02:11 AM
Epoxy has a temperature range for curing depending on the epoxy/hardener used. If you try to use it outside that range, it won’t cure properly or very, very slowly. Give it some heat. Epoxy is exothermic, and heat will speed up the process.
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2847 days
#2 posted 12-28-2015 02:18 AM
What he said.
-- Ken
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3709 days
#3 posted 12-28-2015 02:19 AM
Did you mix the epoxy as designed? Sometimes more hardener is added in the hope of speeding up the curing rate. All this really does us waste hardener and perhaps leave unconsumed hardener possibly affecting the cure.
Robert212
2 posts in 883 days
#4 posted 12-28-2015 02:52 AM
I did mix equal parts of epoxy resin and hardener. The temperature was approx. 60 deg. F during curing. I will heat the piece and hope for the best. Thanks for your suggestions.
View conifur's profile
conifur
955 posts in 1148 days
#5 posted 12-28-2015 03:17 AM
Wifes hair drier!!!!
View clin's profile
clin
841 posts in 993 days
#6 posted 12-28-2015 07:23 AM
- Robert212
Not all epoxy is mixed 1:1.
60 F is pretty cool.
-- Clin
View Tennessee's profile
Tennessee
2873 posts in 2511 days
#7 posted 12-28-2015 01:12 PM
How old was the epoxy. Most people don’t realize it has a shelf life. And the obvious question, how long did you mix it?
If after four days it is not cured, heat may help, but my guess is you are scraping it off and starting over.
4984 posts in 2490 days
#8 posted 12-28-2015 01:14 PM
While it coud be any of the reaons mentioned, I think the best approach may be to wait several days…and adding the heat wouldn’t hurt. I’ve used a brooder lamp hanging over it in the past with good results.
View distrbd's profile
distrbd
2252 posts in 2443 days
#9 posted 12-28-2015 02:44 PM
I have not done this myself but I have read that if your ratio is not correct (which makes your mixture not cure properly),you could pour a new layer of properly mixed epoxy over the old/tacky one and that is supposed to take care of the problem.
I always empty the two potions into a third container and mix the heck out of it until I start getting tiny bubbles floating in the air ,then pour it on the surface, use a heatgun to get rid of the bubbles.so far have not had any surprises.
-- Ken from Ontario, Canada
View Harry's profile
Harry
80 posts in 1177 days
#10 posted 12-28-2015 02:52 PM
I highly doubt this helps but years ago, I used a 3 part epoxy and forgot to add the 3rd (small tube, catalyst). What a serious mess!
-- Harry - Professional amateur
MrUnix
#11 posted 12-28-2015 04:02 PM
How old was the epoxy. Most people don t realize it has a shelf life. And the obvious question, how long did you mix it?
- Tennessee
That’s the first time I’ve heard of two part epoxy having a shelf life unless improperly stored! System Three says ”All solvent-free epoxies have essentially unlimited shelf lives so long as they are stored in sealed containers.” (Ref: System Three FAQ) I have some West System epoxy that I bought maybe 10 years ago and it is still perfectly usable, although the hardener has turned a bit amber.
Proper mixing and cure temperature is important though.. and 60F is on the low side of what is acceptable unless using a hardener specific for lower temperature. Again, the System Three FAQ says:
My epoxy resin is taking too long to cure. How can I speed it up?
The only way to speed the cure of our epoxy resin products, once they’ve been applied, is to heat the room or the area that your project is in. Every 18°F increase in temperature cuts the time it takes for the resin to cure in half.
Tennessee
#12 posted 12-28-2015 05:51 PM
I agree it is a heck of a long shelf life as long as it is in sealed containers. I’ve heard stories of people having it last well over a decade. I think on one forum I saw where a representative of an epoxy company said they had tests going out 28 years and it still worked. Totally sealed containers, of course, and no crystallization of the resin. That can be reversed by heating, though.
But the hardener is what goes when it goes. Turns amber, then when bad turns a reddish amber. At that point, it loses the ability to cure. Not sure on the chemistry – something called a diamine.
