Electrolisys trouble
Forum topic by Alonso posted 01-17-2010 07:57 AM 1719 views 0 times favorited 20 replies Add to Favorites Watch
View Alonso's profile
Alonso
949 posts in 3319 days
01-17-2010 07:57 AM
Topic tags/keywords: electrolisys baking soda washing soda plane restoration rust removal
Hey folks,
I’m almost ready to start using the Electrolisys rust removal to restore my bench planes and several other tools that I’ve been gathering lately at local garage sales and flea markets, but….
I just can’t find washing soda anywhere….!!!!!
Is there another option or substitute for washing soda that may give me the same results, I read that if you cook baking soda at 350f for an hour or so, you will end up with washing soda aka sodium carbonate.
Please I really need some input on this, any help like always is really appreciated.
Alonso
btw, I already tried Evaporust, I like it , but now I want to try this other method …..
-- The things I make may be for others, but how I make them is for me.
20 replies so far
View Jeison's profile
Jeison
968 posts in 3188 days
#1 posted 01-17-2010 09:04 AM
Try anyplace that carries pool supplies, if all else fails you can order direct
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
TopamaxSurvivor
18335 posts in 3756 days
#2 posted 01-17-2010 10:07 AM
ehow claims it will work. http://www.ehow.com/how_5598724_make-washing-soda-baking-soda.html
View Blake's profile
Blake
3443 posts in 3955 days
#3 posted 01-17-2010 06:41 PM
I had to go to the “fancy” grocery store. Safeway (our main grocery chain) didn’t carry it.
-- Happy woodworking!
View poopiekat's profile
poopiekat
4369 posts in 3815 days
#4 posted 01-17-2010 07:07 PM
Though Evap-o-rust is probably cheaper in the US than here, it becomes a struggle to evaluate whether there is enough net gain in the value of the tool to justify a derusting treatment using the solvent in the first place. A common #4 plane? Cheaper to just buy a new one, for example. I’m going to do some electrolysis experiments as soon as the weather goes above freezing. I want to de-rust some wheels to my old truck, for example. It would take 5 gallons of Evaporust…and these wheels are certainly not worth $162.50 each!
Alonso
#5 posted 01-17-2010 10:08 PM
Ok, so I went to my local pool supplies and they told me that Soda ash is the same as sodium carbonate, maybe it is since it seems to be some kind of corrosive after all.
Now the issue is that the parts are in the mixture of water and soda ash but no changes at all, they been on the water for about 1 hr already and nothing. I’ll go ahead and change the water for hot water and see if that makes a difference…..
Alonso
View ajosephg's profile
ajosephg
1880 posts in 3642 days
#6 posted 01-17-2010 10:22 PM
Hmm – assume you got the battery or equivalent hooked up correctly?
-- Joe
Alonso
#7 posted 01-17-2010 10:42 PM
yes… red wire to the re-bar (anode) and black wire to the pieces being de-rusted…. 1/2 hr already on hot water and still nothing…. the meter on the battery chager still at 0 amps…. I wonder if I may need another charger, even though thin one is brand new…
ajosephg
#8 posted 01-17-2010 11:13 PM
Got a voltmeter? No amps kinda sounds like the charger is not putting out. Think I heard that newer charges won’t work without out a real battery in the circuit.
You could hook it to your car battery for a few minutes to see what happens.
-- Joe
TopamaxSurvivor
#9 posted 01-17-2010 11:34 PM
Your charger is probably the problem. And, are your chemnicals disolved? Hook up with a battery and let the charger charge the battery.
View willy3486's profile
willy3486
77 posts in 3478 days
#10 posted 01-17-2010 11:54 PM
I use this method to clean rust and loosen parts. I tried a battery charger at first and it was really slow. I work in electronics for years and I have a industrial dc power supply. I use it now and its really fast. I can do decent size part in a hour or less. I got a delta 24 inch scroll saw and had it apart. I was able to clean the parts ,paint it and get it back together in one day. The power supply goes up to about 180 DC and is adjustable. I run it up until it starts bubbling a little. The water will be warm in about 5 minutes. If yours is the type that has 12 volts even if the battery is not on it the reason it seems like its not working may be due to it being slow to clean. Use a meter as posted and if the voltage is there it may be due to just taking a long time. I read somewhere it can take 24 hours or longer.
View AjayO's profile
AjayO
27 posts in 3551 days
#11 posted 01-18-2010 12:34 AM
Hello Alonso,
I have used Arm & Hammer “baking soda” as washing soda for some reason is hard to find. I use a battery charger keeping it limited to < 2Amp rate and it works fine. It was about a year ago, but I may have used just cold water or may be warm. I used a large 5 gal. plastic bucket lying around and put few tablespoons of baking soda. I added more soda to get decent “bubbling” and have re-used to solution couple of time.
As stated above good electrical connection and correct polarity is a must for the process to work, but is pretty straight forward otherwise.
Good luck!
- Ajay
-- - Ajay
AjayO
#12 posted 01-18-2010 12:42 AM
If the charger is putting out voltage (assumed you have done that as suggested by others), I would suggest checking electrical connections again and making sure you are not creating a “short” in the bucket, which would cause 0 Amp reading even though your charger is just fine. Also, the distance between the electrodes also makes a difference.
-Ajay
-- - Ajay
ajosephg
#13 posted 01-18-2010 03:02 AM
Big Time Caution if you use a high voltage power supply as Willy does. Depending on where and how well your body gets across it even 40 volts can kill you.
-- Joe
View JayPique's profile
JayPique
61 posts in 3369 days
#14 posted 01-18-2010 03:17 AM
Definitely the battery charger – the new ones don’t work.
View HokieMojo's profile
HokieMojo
2104 posts in 3809 days
#15 posted 01-18-2010 03:37 AM
I didn’t read all the posts, but I’ve heard the newer chargers sense something is “wrong” since it isn’t seeing the normal activity it would see when charging a battery. Just something you might want to consider. I spliced a laptop power inverter to get my power source, but please please please, don’t take my advice at face value. research on your own.
