Saw Blade Maintenance 101
« back to Coffee Lounge forum
Forum topic by wookie posted 01-16-2010 10:42 AM 1648 views 0 times favorited 5 replies Add to Favorites Watch
View wookie's profile
wookie
154 posts in 3288 days
01-16-2010 10:42 AM
Topic tags/keywords: maintanance saw blades tip
I noticed that my brand new Avanti 60t blade for my miter saw is starting to rust around the gullets/ carbide tips area. Everything is in the garage that is not heated. What can I do to clean it up and to prevent it in the future? Also, my new dado set came with oil on the blades and I just wiped it off. Should I clean them with acetone and how should I keep them and all my blades from rusting. I need a crash course ASAP!!!!!
-- Wookie=Wood Rookie
5 replies so far
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3549 days
#1 posted 01-16-2010 03:42 PM
The brown is probably pitch, not rust. Not too bad to clean. I use blade cleaner purchased from Woodcraft and a cheap bristle brush from HD. Follow the instructions on the cleaner bottle. To soak the blade, I use a plastic dish that is supposed to be underneath a flower pot. You can get those without the flower pot at KMArt, or just about anywhere.
You don’t need acetone to clean your blades. Just use a spray cleaner and dry your blades well. The unfortunate thing about a garage shop is exposure to moisture. That will cause rust. Especially if you are pulling wet cars into the garage.
wookie
#2 posted 01-16-2010 06:32 PM
Thanks Paul,
That is most likely what it is. Freaked me out though. Great advice. I am new to all this and learning a lot along the way and that is the fun of it. Thanks for responing so quickly.
View Padre's profile
Padre
930 posts in 3693 days
#3 posted 01-16-2010 07:10 PM
Regular stove cleaner works great on blades too to get the pitch and other debris off.
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
View Mark's profile
Mark
1811 posts in 3478 days
#4 posted 01-16-2010 10:30 PM
WD-40! I wipe all my steel down with it. Its like windex for steel..lol
-- M.K.
wookie
#5 posted 01-18-2010 05:02 PM
Thanks again, Guys. The gunk came right off.
