Question Help me decide on a garage shop heating solution
Forum topic by hhrahman posted 12-26-2015 04:20 PM 1061 views 0 times favorited 19 replies Add to Favorites Watch
View hhrahman's profile
hhrahman
6 posts in 759 days
12-26-2015 04:20 PM
Topic tags/keywords: garage heating
Hi,
This is my first post. I’m looking for some advice from you knowledgable folks. Any help is much appreciated!
I’m looking at having a Carrier 58CTA070 (http://www.carrier.com/residential/en/us/products/gas-furnaces/58cta/) unit installed in my garage attic (the manual actually has instructions for an attic specific installation). I plan on setting up a woodworking shop in this garage. I will be using a dust collector and for now it is a 1HP with a 1 micron bag. My HVAC guy says he will install a couple of ducts on both sides of the garage and put in a chimney to vent to the outside above the garage.
What I’m unsure about is, because this unit is not sealed combustion, is it safe to use in a woodworking shop or even a garage? My HVAC guys says there isn’t a problem but will not install it if I am not comfortable. The other option is a hot dawg ceiling mounted heater, I’m not sure if those are sealed combustion either but seem to be a popular choice. The Carrier unit will cost me $650 less so I’ll definitely go with that if it’s a safe and good solution.
Hope that made sense and please ask any questions. Really looking to get this installed in the next few days so I can start setting up my shop!
Thanks.
19 replies so far
116815 posts in 3453 days
#1 posted 12-26-2015 04:29 PM
Welcome to Ljs
I’m not a HVAC guy so I would tend to listen to one that you feel he knows what he’s talking about or get a second opinion.
4830 posts in 2369 days
#2 posted 12-26-2015 04:39 PM
The furnaces that aren’t direct vented draw their combustion air from the room they’re in, so if that’s the shop itself it sucks in any any flammable vapors, ambient dust, and whatever. But having it in the attic just means it will draw attic air, which I would think is free of the problem materials from the shop…and i suppose if it’s made for the attic it has some kind of dust trap/filter for the combustion air it draws from the attic. I think you’re good to go, one thing I see you didn’t mention: will there be a cold air return to the shop?
View TinWhiskers's profile
TinWhiskers
179 posts in 828 days
#3 posted 12-26-2015 04:42 PM
You should give us info on size of shop and insulation. Texas or Alaska? What do you fear blowing up? Fumes? Sawdust?
You have a huge shop? Mine is 24×36 x10 insulated to the max. I have a 35K BTU Hot Dawg. I am happy.
View GT350's profile
GT350
361 posts in 1857 days
#4 posted 12-26-2015 04:47 PM
I have a ceiling mounted gas furnace in my shop that pulls combustion air from inside the shop. I have never had a problem, but I run dust collection and I don’t think that you can get enough dust in the air in a home shop where it is explosive. If you are spraying finish you probably should be exhausting the vapor anyway. I don’t think I would want ducted heating because no matter how good your dust collection is you are still going to have dust buildup in the ducts.
Mike
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1052 days
#5 posted 12-26-2015 04:49 PM
Beyond heating, will you ever need AC? Even if you don’t install it now the furnace needs different ducts to allow space for the AC’s A coil to be installed.
View LostHasher's profile
LostHasher
45 posts in 778 days
#6 posted 12-26-2015 04:52 PM
Talked to one of my propane guys about refurbishing my giant garage heater, so I can work in the winter. He noticed the chemicals I had and said “Do NOT use propane or natural gas if you’re going to be refinishing furniture.” Essentially, he didn’t want to see me blowing myself up.
With the information you supplied, it sounds like you might need a second opinion. Maybe call the gas company directly with what you plan to do. (I’m not trying to sound like I know what I’m talking about, or that the propane guy was right… just passing this along.)
View bearkatwood's profile
bearkatwood
1453 posts in 887 days
#7 posted 12-26-2015 05:06 PM
I have the ceiling mounted 220V heater style and I have not had any problems with it and the bill has been very low so far for the last two years. About every 3 months I hit it with a burst of air from my compressor as my shop can get really dusty. I also have an old wood stove in the back corner of my shop and if there was to be any issues with finishing or dust explosions you would think that would do it, but I haven’t had any problems. I don’t spray finish, but I have had a run of 12 chairs being finished with the stove going and not had any issues.
-- Brian Noel
hhrahman
6 posts in 759 days
#8 posted 12-26-2015 05:31 PM
Thanks for all the feedback, it’s very helpful.
My garage is a 20×20x10 in Toronto, Canada. It will be fully insulated and drywalled. Initially my concern is only sawdust and humidity but eventually I will be spraying finishes too.
I asked about the cold air return and my guy said both supply and return will be from the shop so that doesn’t sound good with regards to open flame and filters.
I am also looking into gas radiant tube heating.
hhrahman
6 posts in 759 days
#9 posted 12-26-2015 05:43 PM
GT350, do you have any issues with filter changes? How frequently do you have to swap them out?
TinWhiskers
#10 posted 12-26-2015 05:57 PM
I am curious on your pricing. Is that a 70K BTU furnace?
A 45 K BTU Hot Dawg will run $600. I am adequate with a 35 K BTU in north Ohio with a larger area. You may be a tad colder as in one heating zone. Maybe a second opinion on size?
You seem concerned if your furnace will blow up with your activity. If your explosive levels are that high, don’t forget that any spark from motor startup, light switch…will cause an explosion too.
View jumbojack's profile
jumbojack
1673 posts in 2500 days
#11 posted 12-26-2015 05:58 PM
Is there no way to draw the combustible air from outside?
GT350
#12 posted 12-26-2015 06:19 PM
Hhrahman, I don’t have filters on the furnace because it is just one of the old ceiling mounted gas furnaces, I just occasionally blow the dust off but not much accumulates. As far as my dust collectors, I have two that hang from the ceiling with 3 filters each, a fiberglass filter then a pleated filter and then a bag filter and I just blow them out outsode every few months. I also built the cyclone dust collector that Wood Magazine featured several years ago with a diesel truck filter and every month or so I blow that out.
Mike
hhrahman
6 posts in 759 days
#13 posted 12-26-2015 06:35 PM
The carrier unit is 70k BTUs and will cost me $1000 installed. The hot dawg unit is 60k BTUs and will cost me $1650 installed. I can ask about a lower BTU unit, I have read about a few people using 45k units.
Jumbojack, I thought the forced air unit would draw air from the outside and vent to the outside too but maybe that’s a more expensive unit that allows that. I did tell my HVAC guy that o was on a tight budget and he’s been trying to source cheaper units for me.
hhrahman
6 posts in 759 days
#14 posted 12-26-2015 06:44 PM
Hhrahman, I don t have filters on the furnace because it is just one of the old ceiling mounted gas furnaces, I just occasionally blow the dust off but not much accumulates. As far as my dust collectors, I have two that hang from the ceiling with 3 filters each, a fiberglass filter then a pleated filter and then a bag filter and I just blow them out outsode every few months. I also built the cyclone dust collector that Wood Magazine featured several years ago with a diesel truck filter and every month or so I blow that out.
Mike
- GT350
Nice! Sounds like a good setup you got there.
TinWhiskers
#15 posted 12-26-2015 06:56 PM
Just to give you an example of what a 35K unit would do in Ohio…To go from 50F to 65F would take up to an hour. To maintain a warm temp of 65F is easily done. 24×36x10 area. I have kept it warmer for drying varnish with no problems. A 70K unit for me would be too much which is bad.
