1200 rpm bench grinder?
Forum topic by woodnoobie posted 01-16-2010 08:56 AM 3574 views 0 times favorited 3 replies Add to Favorites Watch
View woodnoobie's profile
woodnoobie
5 posts in 3113 days
01-16-2010 08:56 AM
A few sources have recommended using a 1200 rpm bench grinder for sharpening. None have offered a manufacturer or model. Anyone have a recommendation?
The closest I’ve found are variable speed grinders with the slowest speed at 1725 rpm. These are Delta and Craftsman, which bear an eerie resemblance to one another.
http://www.amazon.com/dp/B0000B3AQQ/ref=asc_df_B0000B3AQQ994674?smid=ATVPDKIKX0DER&tag=googlecom09c9-20&linkCode=asn&creative=380341&creativeASIN=B0000B3AQQ
http://www.sears.com/shc/s/p_10153_12605_00921162000P
Anyone care to offer thoughts on the differences of having a 1200-1725 rpm vs. a standard 3400~ grinder?
Thanks!
Erik
3 replies so far
View Paul M Cohen's profile
Paul M Cohen
86 posts in 3801 days
#1 posted 01-16-2010 09:14 AM
I think you are looking for a 120 RPM or less grinder. Something like a Tormak which I think runs at 90 RPM.
-- Paul, Beaverton OR, www.TravelbyPaul.com
View davidpettinger's profile
davidpettinger
661 posts in 3224 days
#2 posted 01-16-2010 09:21 PM
If you already have a grinder, you may want to look at this website. Fine woodworking has quoted them, along with making the website a readers choice. This company offers stones for both 1725 and 3450 rpm as well as jigs to aid in sharpening your tools.
http://www.oneway.ca/sharpening/index.htm
There is a book offered by Taunton Press called Grind Perfect Edges Without Burning In just seconds, get a tool ready for honing
by Joel Moskowitz
This book explains how to use a higher speed grinder and jigs for sharpening.
-- Methods are many,Principles are few.Methods change often,Principles never do.
TopamaxSurvivor
18285 posts in 3699 days
#3 posted 01-17-2010 01:08 AM
1725 and 3450 rpm are the standard motor speeds depending on whether it is 2 or 4 pole motor. Anything else will have to be gear driven to change teh speed or changed electronically. I don’t have any issues using a 1750 grinder for sharpening.
