Is it worth adding pocket holes to a glue up?
« back to Joinery forum
Forum topic by DTrak posted 12-26-2015 12:46 AM 1081 views 0 times favorited 8 replies Add to Favorites Watch
View DTrak's profile
58 posts in 1028 days
12-26-2015 12:46 AM
I am an amateur and just glued up several boards to make a large tabletop. At first I thought just glue would be enough, but the boards were a little bowed or warped since I didnt have access to a joiner or planer. I glued them all flush(ish) with a clamps and they look ok for the moment, but what I am wondering is will the boards hold together better if I add pockets AFTER I have glued them, or will it make no difference. thanks
8 replies so far
View jeffswildwood's profile
2921 posts in 1908 days
#1 posted 12-26-2015 12:57 AM
I have used pocket holes for this but I did the holes and screwed them in during glue up . Should hold tight if done after but sounds tricky. When I did this I had to make sure it was clamped tightly as kreg screws will move your wood out of alignment if not careful.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View CharlesA's profile
3309 posts in 1728 days
#2 posted 12-26-2015 01:02 AM
For future reference, you’ll want to make yourself some cauls.
I can’t see how pocket screws will help you—the glued edges will be incredibly strong if clamped properly—and the pocket screws won’t pull the boards back into a flat orientation.
View johnstoneb's profile
2816 posts in 2103 days
#3 posted 12-26-2015 01:21 AM
The screws will add little if any strength to the joint.
-- Bruce, Boise, ID
View dhazelton's profile
2719 posts in 2227 days
#4 posted 12-26-2015 01:36 AM
Screws would have aided as clamps during the glue up. The glue does most of the work.
#5 posted 12-26-2015 01:39 AM
Ok, so rare for such consensus. Thanks the feedback all.
CharlesA, good tip about cauls. As you prob suspected, I didn’t know about such things. Makes a lot of sense.
View mchapman87's profile
43 posts in 809 days
#6 posted 12-30-2015 11:28 PM
I built a small end table out of reclaimed oak hardwood flooring. I used pocket screws as I glued the piece up. I found that I was able to use the screws to keep the surface flat without constant re-adjusting of clamps and boards to work them flat. I glued and then screwed together before I clamped up. There was little to no twist, or protruding edges on the surface. I wouldn’t say it’s necessary to do it this way, I just found comfort in knowing that even if the clamp slips the screws will hold the piece in place as the glue sets, and dries.
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes!
View rwe2156's profile
2834 posts in 1411 days
#7 posted 12-31-2015 11:12 AM
I never do it anymore, but you can also work around the problem by using biscuits.
Arrange any bowed boards opposite to attempt to cancel out the bow (not really sound, but sometimes it works).
Always keep your wood a bit oversized of course if you’re buying it from box store already 3/4”.
In lieu of jointer you can use handplanes to flatten boards.
View Alongiron's profile
645 posts in 2624 days
#8 posted 12-31-2015 11:56 AM
A couple of ideas here. If you are looking for strength of the joint and this is a light duty table, glue itself will be fine but using biscuit joinery will help with the alignment of the pieces. If you are looking for strength of the joint on a heavy duty table, I would consider using full length splines at each joint. These will help with both alignment and strength. The screws that you are talking about will only aid while the glue dries. If you do not have a biscuit jointer there are a lot of good videos on you tube. Again they are good for alignment and splines are good for strength. Also consider the growth rings on your boards. Alternating the growth rings up and down will help to keep the table flat. Hopes this helps.
-- Measure twice and cut once.....sneak up on it! Steve Lien
