Thinking about this for chisels and bench/block plane sharpening, feed back please
« back to Hand Tools forum
Forum topic by conifur posted 12-26-2015 12:07 AM 1397 views 0 times favorited 12 replies Add to Favorites Watch
View conifur's profile
conifur
955 posts in 1028 days
12-26-2015 12:07 AM
Thinking about this for chisels and bench/block plane sharpening, need your comments or suggestions for a different one. Plus stone or diamond?
http://www.woodcraft.com/product/153784/veritas-sharpening-system.aspx
12 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 2829 days
#1 posted 12-26-2015 12:21 AM
I have that honing guide. Frankly, I rarely use it. Only a couple of times with a wide, beveled plane blade. Other than that, I don’t use it. Why? Because I got it in a package deal that included the other Veritas honing guide which I like very much. This one:
http://www.woodcraft.com/product/833173/veritas-mk-ii-honing-guide.aspx
This is a much better guide and only a few dollars more. You will probably be happier with the MKII. Easy to set up, easy to use, and gives very good results.
Good Luck!
-- Mike
View David Taylor's profile
David Taylor
326 posts in 964 days
#2 posted 12-26-2015 01:58 AM
I agree with Mike. Got the one you linked to, fought with it too much, moved to the MKII, and am very happy.
-- Learn Relentlessly
View bearkatwood's profile
bearkatwood
1453 posts in 888 days
#3 posted 12-26-2015 02:04 AM
I use the MKII with DMT fine and extra extra fine diamond plates and then hone with compound on a block of hardwood, the whole operation takes only minutes to get razor sharp.
-- Brian Noel
conifur
#4 posted 12-26-2015 02:09 AM
Ya in my price range and looked at it too, but the size of chisels and only 1.5”’ wide for planer blades and mine are a bit wider, if I go to the wider one, it wont handle my smaller chisels, they just keep fa fa fa!!!! Chris Rock in Leatal Weapon 3
View jmartel's profile
jmartel
7635 posts in 2027 days
#5 posted 12-26-2015 02:14 AM
I’ve sharpened a 1/8” chisel on the Mk. II. Also sharpened a 2 5/8” plane blade on it. Should cover just about everything. The only exception would be something like a mortise chisel where it’s got too much of an angle from the face and the back.
View BurlyBob's profile
BurlyBob
5157 posts in 2142 days
#6 posted 12-26-2015 03:25 AM
I totally concur. Doubt I could the results I do with my chisels and irons without my MKII. I use wet/dry paper to 2500 grit on a piece of granite countertop. I’m very satisfied with the results.
View bandit571's profile
bandit571
18950 posts in 2560 days
#7 posted 12-26-2015 03:51 AM
Been using the MK1 since it came out. Lately, it has been used to re-establish a bevel. IF I want a 25 degree bevel on a blade, I can set it up with the MK1. Then I final sharpen by hand. About the only thing I have trouble with is the tapered plane irons, like from Ohio Tool Co./Auburn Tool Co. planes.
View ksSlim's profile
ksSlim
1264 posts in 2767 days
#8 posted 12-26-2015 07:45 AM
If you have an MKII, you can also use the “narrow blade holder” also from LV.
Works nicely down to 1/8 inch.
-- Sawdust and shavings are therapeutic
View AandCstyle's profile
AandCstyle
2951 posts in 2134 days
#9 posted 12-26-2015 01:12 PM
I’ll cast another vote for the MK II. LV is offering free shipping until January 5th for orders >$40.
http://www.leevalley.com/US/Wood/page.aspx?p=51868&cat=1,43072,43078&ap=1
-- Art
conifur
#10 posted 12-26-2015 01:56 PM
The Mark II standard size will handle my plane irons width but chisels only down to 1/2”’ in width.
jmartel
#11 posted 12-26-2015 07:01 PM
The Mark II standard size will handle my plane irons width but chisels only down to 1/2” in width.
- conifur
No, it holds thinner than that. I have the same Mk II jig you do and sharpen an 1/8” chisel just fine.
conifur
#12 posted 12-26-2015 07:17 PM
Then the specs in the description is incorrect. If so from all here that is the one I will get, the M kII standard size.
Yes wood craft sez to 1/4”’ , It was the other site I was looking at that said to 1/2”’. Thanks.
