How to prevent wood splintering when drilling?
« back to Hand Tools forum
Forum topic by jess2772 posted 12-25-2015 11:41 PM 1602 views 0 times favorited 7 replies Add to Favorites Watch
View jess2772's profile
jess2772
1 post in 791 days
12-25-2015 11:41 PM
I need to drill holes about half-way into the wood, and each time I do the wood splinters pretty badly. I can’t really use the tape/piece of wood method because the hole doesn’t go all the way through the wood. How can I prevent the wood from splintering? The bit is 1/8” and the surface is slightly curved.
7 replies so far
View MadMark's profile
MadMark
979 posts in 1361 days
#1 posted 12-25-2015 11:47 PM
Your bit is dull. Take smaller bites. Worst case is to predrill with a smaller bit.
View paratrooper34's profile
paratrooper34
915 posts in 2860 days
#2 posted 12-25-2015 11:56 PM
When I drill holes in places where I don’t want splintering, I run the drill in reverse and gently push the bit onto the surface of the wood. This allows the bit to score the wood and make a very clean entry without splintering. After the scoring is done, put it in forward and drill away.
-- Mike
View Tim's profile
Tim
3734 posts in 1869 days
#3 posted 12-26-2015 12:53 AM
Tried brad point bits? I just got these for Christmas so I can’t personally recommend them but they were recommended highly:
http://www.leevalley.com/US/wood/page.aspx?p=42247&cat=1,180,42240,42247
You could also try sharpening your bit.
View dhazelton's profile
dhazelton
2689 posts in 2204 days
#4 posted 12-26-2015 01:40 AM
If it’s pine it’s going to splinter. What kind of wood?
View David Taylor's profile
David Taylor
326 posts in 995 days
#5 posted 12-26-2015 02:00 AM
What Tim said. I’ve had them for years, they make a nice clean hole, both entry and exit.
-- Learn Relentlessly
View rwe2156's profile
rwe2156
2803 posts in 1389 days
#6 posted 12-26-2015 11:38 AM
Brad point bit that’s what they’re made for.
You can get a set reasonably cheap.
View Knothead62's profile
Knothead62
2581 posts in 2869 days
#7 posted 12-26-2015 03:15 PM
Brad point bits. Woodcraft has a BP drill bit set on sale. 100 piece set for $24.99; #158296. Contains twist bits and brad point bits in various sizes. Got the set this past spring- good quality.
