hand plane "shutter"
« back to Hand Tools forum
Forum topic by dbw posted 12-25-2015 10:49 PM 711 views 0 times favorited 8 replies Add to Favorites Watch
View dbw's profile
dbw
197 posts in 1542 days
12-25-2015 10:49 PM
Topic tags/keywords: hand plane shutter mill marks
Folks, I am getting “shutter” while removing mill marks from the edge of soft maple boards. This doesn’t happen every time. The hand plane in question is a Stanley Sweetheart #4. I honed the iron with a Veritas Mark II and I also honed a micro bevel. I can shave the hair on my arm with the iron after I get done honing so I don’t think it’s the sharpness of the blade. I am taking very thin bites and I’ve got the throat closed way down. Any ideas?
-- measure 3 times, cut once
8 replies so far
View TheFridge's profile
TheFridge
8892 posts in 1392 days
#1 posted 12-25-2015 10:51 PM
Open the mouth a bit?
View MadMark's profile
MadMark
979 posts in 1358 days
#2 posted 12-25-2015 11:07 PM
Plane in the other direction …
View AZMike's profile
AZMike
14 posts in 1943 days
#3 posted 12-25-2015 11:16 PM
Make certain that your cap iron is contacting the blade all the way across the width of the blade, at the front of the cap iron. When tuning a handplane the condition and fit of the cap iron is as critical as the sharpness of the blade. I usually locate my cap irons about 1/32 back from the edge of the blade. Also cap iron must be rather snug, but not over-tightened. Another thing is when you are setting the blade exposure always do it in the ADVANCING direction. Adjusting in the RETREATING direction will cause chatter (shutter).
View chrisstef's profile
chrisstef
17174 posts in 2912 days
#4 posted 12-25-2015 11:22 PM
What mark said.
View Bill White's profile
Bill White
4856 posts in 3866 days
#5 posted 12-25-2015 11:26 PM
Shudder/chatter can also be caused if the frog is not seated properly.
Bill
-- bill@magraphics.us
View paratrooper34's profile
paratrooper34
915 posts in 2857 days
#6 posted 12-25-2015 11:41 PM
Check to make sure the lever cap is tight enough. Loose frog could be issue as well. Good Luck.
-- Mike
View dbw's profile
dbw
#7 posted 12-25-2015 11:41 PM
In this plane the frog is part of the casting and the cap iron is 1/32” back from the edge and it is snug. I think my issues are mouth not open enough, wrong planning direction and planning after adjusting the blade exposure in the retreat direction. You folks are AWESOME!! thanks.
View dhazelton's profile
dhazelton
2689 posts in 2202 days
#8 posted 12-25-2015 11:57 PM
I would echo a couple of posts above, either trying to take off too much or switch directions.
