High-end saw blade (10") for flat dado's
« back to Joinery forum
Forum topic by MNgary posted 12-25-2015 06:24 AM 1263 views 0 times favorited 16 replies Add to Favorites Watch
View MNgary's profile
MNgary
301 posts in 2440 days
12-25-2015 06:24 AM
I need to cut dado’s that leave a perfectly flat ‘bottom of the dado’. Prefer doing it on my 10” cabinet saw.
Blade recommendations or alternatives???
-- I dream of a world where a duck can cross the road and no one asks why.
16 replies so far
View lateralus819's profile
lateralus819
2241 posts in 1913 days
#1 posted 12-25-2015 06:35 AM
I have the DeWalt kit. I like it a lot. Comes with a nice case too.
View newwoodbutcher's profile
newwoodbutcher
744 posts in 2873 days
#2 posted 12-25-2015 07:00 AM
I’e had the Forrest dado set for twenty years and am very happy with the performance.
-- Ken
View MrUnix's profile
MrUnix
6764 posts in 2222 days
#3 posted 12-25-2015 07:21 AM
I’ve never seen a dado stack that will leave a perfect cut – although I’m sure there might be something out there that can. See this thread started by Scott for examples. Alternative? I’d consider using a router if you need an absolutely flat bottom.
View Fettler's profile
Fettler
200 posts in 2020 days
#4 posted 12-25-2015 07:30 AM
Maybe a router? If you’re cutting dados in non-engineered wood (natural wood) then you can achieve final depth with a router plane.
-- --Rob, Seattle, WA
View Andre's profile
Andre
1869 posts in 1829 days
#5 posted 12-25-2015 09:05 AM
Lee Valley sell a Dimitar 24 tooth rip blade with Flat top, excellent blade, they also have the 8” Finger Box set with Flat top which I just picked up but haven’t had a chance to try yet!
View knotscott's profile
knotscott
8055 posts in 3399 days
#6 posted 12-25-2015 02:14 PM
Box joint sets, FTG rip blades, and router bits will leave truly linear flat bottoms, but will leave more tear out on cross grain cuts. Stacked dado sets can get close, but do leave some bat ears….it’s by design so they’ll have good cross grain performance too.
If you still want a stacked dado. The DW/Delta 7670 set is one of the best values in the $120 range. The Infinity Dadonator is the best performer I’ve used, but runs ~ $200+
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1200 days
#7 posted 12-25-2015 02:29 PM
Whatever you choose stay away from the wobble dado adjustable sets. Personal experience shows that they leave a very uneven bottom and have bad tear out.
View sawdustdad's profile
sawdustdad
357 posts in 908 days
#8 posted 12-25-2015 02:31 PM
I’ve switched to the router for many dado cuts. The time to set up the stacked dado on the table saw vs. changing a bit on the router table (which is actually mounted on the extension table of my TS and uses the same fence). The accuracy of the router bits reduces set up time and bits for plywood thicknesses are available as well.
Not sure if this will work for you, but something to consider.
With a stacked dado set, I always need to use a router plane or chisel to smooth the little nubs out of the bottom of the dado anyway.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View bearkatwood's profile
bearkatwood
1592 posts in 1035 days
#9 posted 12-25-2015 04:17 PM
I bought my set last year and love it, they leave a very clean dado and they sound like a freekin airplane taking off when I raise it up to full height to cut out notches for back chair legs.
http://www.amazon.com/Oldham-1005824-10-Inch-General-Purpose/dp/B0000DD1BW/ref=sr_1_2?ie=UTF8&qid=1451060125&sr=8-2&keywords=10%22+dado+set
-- Brian Noel
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1248 posts in 1736 days
#10 posted 12-25-2015 04:47 PM
The obvious answer would be to use a spindle shaper cutter made for the purpose. Some should fit the arbor of your ts. For instance like this one: http://www.tctrouterbit.com/china-adjustable_grooving_shaper_cutter_head_with_black_steel_body_woodworking_cutter-990823.html
-- "Do or Do not. There is no try." - Yoda
View rwe2156's profile
rwe2156
2961 posts in 1504 days
#11 posted 12-25-2015 06:06 PM
Of course I guess the Forest is the best.
I’ve had good luck with my Freud set but – the last time I got it sharpened the blade tips on one or more spacers are off.
I don’t worry about it anymore becasue I’ve evolved to leaving it just shy and finishing out a dado with a router plane.
This ensures uniform depth across the board, which you cannot get with a dado set because any slight concave cup will leave the dado depth shallower in the middle.
MNgary
#12 posted 01-22-2016 04:42 PM
Thanks, all, for the feedback. I will look at router bits.
View Gene Howe's profile
Gene Howe
10524 posts in 3452 days
#13 posted 01-22-2016 04:57 PM
My dado set is a Tenryu. I had my outside blades ground to eliminate the bat wings. Works fine.
View pintodeluxe's profile
pintodeluxe
5702 posts in 2836 days
#14 posted 01-22-2016 05:19 PM
I find most dado sets will give a nice flat bottomed groove. I never show the dado in a finished project, so the tiny bat ears are never an issue. You have to look pretty close to even see them.
The one place I initially thought it might be more critical is with through tenons. However if you plan to make a full-width cut at the exposed tip of the tenon, it’s a non-issue.
View shampeon's profile
shampeon
1775 posts in 2207 days
#15 posted 01-22-2016 05:25 PM
I have a Freud box-joint set that cuts true flat bottoms.
http://www.amazon.com/Freud-SBOX8-Cutter-4-Inch-grooves/dp/B000ASGV1E
