I have 6 Magnolia shade trees that must be removed as they are damaging concrete and getting into the power lines.
The trees are from 10"D to 18"D. When cut, they should yield 6' to 10' logs. I have access to a Woodmiser mill for milling.
Questions: Is the wood desirable? How does it turn? Are the boards stable during the air-drying process? Is the wood stable after including in a project? How does it take finishes, stain? Is it desirable? Special milling required?
Should I spend the time and money to mill this lumber?
Any help or thoughts would be appreciated.
