Building a box...
Forum topic by DaveA posted 01-15-2010 02:02 AM 1088 views 0 times favorited 2 replies Add to Favorites Watch
View DaveA's profile
DaveA
46 posts in 3044 days
01-15-2010 02:02 AM
I am nearly completed with my first chess table. So far so good.
I decided it might look better and be more functional if it sat on a box type of base. I found some wood for the base and afterward discovered I cut all my pieces out of Aspen. It was then I realized I was in for another staining nightmare. So I think I will leave it natural.
My thought now is to dress it up a little bit so it’s just not another box with mitered corners. I thought I would put those wedges or whatever they are in the outside corners. Can someone tell me what those are actually called and maybe some simple direction as to the technique.
I may be misguided, but I thought I saw some type of jig on LJ that would put the box on a 45 angle and then you run the jig over the saw blade cutting a kerf through the piece. Is that correct?
Edit: I think I found something, Miter keys! That’s what I want to do.
-- Dave - Milwaukee
2 replies so far
View WoodshopJoe's profile
WoodshopJoe
99 posts in 3222 days
#1 posted 01-15-2010 08:39 AM
Dave if you are still looking for how to make a good mitered corner box with splines, Andy made a tutorial in his Blog located here. He shows the jig and blade he used for his boxes and also has a jig for the miter saw for the mitered corners. Actually they are bevel cuts. I made a similar stop system for my table saw that is mounted on a sled. I find that for box sides that are taller it is better to use the table saw. Eagle River Woodworking has a great tutorial on how to make their “Super Sled” you can view here. Good luck with your box.
-- Joe Truehart - The Craftsmans Woodshop
DaveA
#2 posted 01-15-2010 03:17 PM
Thanks Joe, the tutorial was very helpful.
The process appears to be easier and less complicated than I thought it was. I think I can muddle through this one.
-- Dave - Milwaukee
