Craftsman Table Saw with some vibration issue...
Forum topic by Ripper70 posted 12-24-2015 03:29 AM 3146 views 0 times favorited 28 replies Add to Favorites Watch
View Ripper70's profile
Ripper70
1196 posts in 1147 days
12-24-2015 03:29 AM
Hey All,
Thanks everyone at LJ that helped me zero in on a used TS that I picked up on craigslist the other day. I finally settled on a Craftsman 113.298240 with a Biesemeyer fence. Paid $100 bucks for it and I’m pretty happy with the purchase. I think I got a pretty good deal on a saw that’s a perfect fit for my needs.
Now, transporting the saw required removing the fence rails, so when I got her home, I figured I’d do a thorough cleaning of the case and check the machine over before I reassembled it. I noticed that the motor was mounted with the vents facing up so I thought it would be prudent to reorient the motor with the capacitor on top and the vents facing downward as instructed in the manual. However, when I finished that and started her up, there was a considerable amount of vibration (see video below) especially so right at the moment of startup as well as when she winds down.
The motor is mounted to a base, which uses a pivot screw that enables the motor to change position based on the blade height setting, and uses the weight of the motor to maintain the tension on the belt and pulley. Seems as if this is a vulnerable spot seeing as how the motor is pretty much floating at all times.
What adjustments do you all think are required to get this saw running more smoothly? Any advice/suggestions would be greatly appreciated.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
28 replies so far
View johnstoneb's profile
johnstoneb
3072 posts in 2411 days
#1 posted 12-24-2015 03:46 AM
I think the belt may have taken a set. Replace the belt and see what happens.
-- Bruce, Boise, ID
View jmartel's profile
jmartel
8279 posts in 2389 days
#2 posted 12-24-2015 03:48 AM
Put a link belt on it. Harbor Freight sells them really cheap. My craftsman TS used to do that as well until I put a link belt on it. Then it smoothed way out.
http://www.harborfreight.com/vibration-free-link-belt-43771.html
And use a 20% off coupon on it.
View matt garcia's profile
matt garcia
1904 posts in 3911 days
#3 posted 12-24-2015 03:58 AM
My Delta had the same issue. I put a link belt on it and haven’t had a problem since.
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
View Festus56's profile
Festus56
3545 posts in 1467 days
#4 posted 12-24-2015 04:51 AM
I have had the same model saw for 20 years and like it. As already said replace the belt and it will be good.
-- Mark -- Really we're not crazy, just "Limited Editions" -- http://www.jmh-limited-editions.com/home.html --
Ripper70
#5 posted 12-24-2015 04:57 AM
Well, it’s unanimous! I had a feeling the belt would be the answer but wanted to make sure because I had no idea that the motor was mounted on a pivoting bracket.
I’ll head over to Harbor Freight tomorrow, get the link belt, and give it a go.
Thanks, gents.
View knotscott's profile
knotscott
8178 posts in 3614 days
#6 posted 12-24-2015 12:15 PM
Very likely belt related, which could also include damaged pulleys, loose pulleys, bad pulley alignment, or could include belt tension. Check that all the nuts and bolts on the motor, motor mount, and pulleys are all tightened down (...at least the ones that are supposed to be tight!).
View Tennessee's profile
Tennessee
2893 posts in 2753 days
#7 posted 12-24-2015 12:46 PM
I also vote for the belt. You can see the slight hop when it comes around during the slowdown right at the end of the video.
View dhazelton's profile
dhazelton
2805 posts in 2535 days
#8 posted 12-24-2015 02:41 PM
Also make sure the holes in the motor mount plate aren’t wallowed out at all.
Ripper70
#9 posted 12-24-2015 02:44 PM
Also make sure the holes in the motor mount plate aren t wallowed out at all.
- dhazelton
Not sure what you mean by that.
View ChefHDAN's profile
ChefHDAN
1230 posts in 3088 days
#10 posted 12-24-2015 03:56 PM
My Ridgid is close to the same saw, the link belt won’t work unless you change the pulleys, I went cheapest route first with a new flat belt and the vibrations were gone, that was 8 years ago still haven’t gone to the lengths of replacing he pulleys and getting the link belt though I did put one on the BS, which already had v-belt pulleys.
View JollyGreen67's profile
JollyGreen67
1676 posts in 3002 days
#11 posted 12-24-2015 05:12 PM
For thought – the green link belt at HF is made in Italy – NOT CHINA! My Craftsman had the same problem, and the link belt cured it. The red link belt, at $5 a foot is made in China.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View toolie's profile
toolie
2148 posts in 2867 days
#12 posted 12-24-2015 05:18 PM
- dhazelton
there are two rods extending from the motor mount that go into two holes in the saw. the rods are held in place by two 1/2 or 9/16” bolts that tighten down onto the rods. performance of those saws is materially affected by how much those rods are buried in the saw. check for an OM for a complete description because the weight of the motor is what tensions the belt. when those saws are set up correctly, a nickel will balance on the saw during a 45° bevel rip.
good luck.
- Ripper70
View rmoore's profile
rmoore
325 posts in 2874 days
#13 posted 12-24-2015 05:36 PM
I would try tightening the bolt that the motor pivots on. Adjust the belt where it should be, then tighten the bolt. I can see the motor bouncing toward the end of the video. Just using the weight of the motor will let the belt slip sometimes in thick or hard wood.
-- The more I learn, the more I realize I don't know. Ron, Crossville Tn
knotscott
#14 posted 12-24-2015 07:22 PM
My Ridgid is close to the same saw, the link belt won t work unless you change the pulleys, I went cheapest route first with a new flat belt and the vibrations were gone, that was 8 years ago still haven t gone to the lengths of replacing he pulleys and getting the link belt though I did put one on the BS, which already had v-belt pulleys.
- ChefHDAN
Your Ridgid uses a ribbed serpentine belt with proprietary pulleys. The guts are very similar to the Craftsman’s, but the Cman uses traditional v-pulleys, which should work fine with the link belt. There are higher end precision pulleys available, but I wouldn’t change those needlessly unless there’s an issue.
Ripper70
#15 posted 12-24-2015 08:10 PM
Thank you all for the replies. I’ve gotten the green belt from HF as well as their mobile base for the saw. I’ll install the belt before replacing any pulleys and see if that cures my ills. As soon as I get it all hooked up I’ll report back with the results.
showing 1 through 15 of 28 replies
